Frnt lower control arm bolt stuck.
Old May 9, 2010 | 03:48 PM
crimson's Avatar
I have a 92 Camaro rs. when i went to remove the control arm to replace my bushings and ball joint i realize the rear bolt is stuck to the inner bushing and i cant get the bolt out. Ive tried hammering cutting turning everything i can think of and i cant get it off.
Old May 9, 2010 | 03:59 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Frnt lower control arm bolt stuck.
Common problem. I used a gallon of WD-40, a chisel which I used under the head of the bolt, and a four-pound sledge. The single bolt took an hour or so to remove--I experienced the same situation of on the other side. When I replaced, I slathered the bolts with anti-seize. Good luck. I'm feeling your pain.
JamesC
Old May 9, 2010 | 04:05 PM
crimson's Avatar
i forgot to mention the inner bushing is disconnected from the rest
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
