Lowering with Drop Spindles...
Old Jan 24, 2001 | 10:02 PM
Bort62's Avatar
Once i get My BMR springs in and On, If that doesnt Lower My car Enough For My tastes, I know I can Go to Drop Spindles in the front For another 2" approx without Screwing up the Geometry, Right ?
But what about the back ?
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jan 24, 2001 | 10:44 PM
Mike Harvey's Avatar
Your right about the dropped spindles. The only way to lower the rear is either cut the springs or get lowering springs but I would personally choose lowering springs.
- Mike Harvey -
1986 Firebird S/E
Old Jan 31, 2001 | 06:45 AM
Nitro Don's Avatar
I went this route.
1.5" lowering springs and 2' BellTech spindles.You will have to get the car an alinement.The front is soo low that I had to cut some metal out of the upper fender so the tire clears.It will put the top of the tires in the fenders slightly.The back is just the 1.5 drop.It has a slight rake look to the car.I havent decided if Im going to cut the bnack springs to level out the car or not.
It is extremly low and you will bottom out on everything you see,but it looks really good.
Nitro Don
1990 Trans Am WS6
305TPI 700R4
ENGINE:
150hp NOS kit
March underdrive pulleys
Edelbrock headers(JetHot)
Mac off-road pipe
Flowmaster exaust
Jacobs ultra coil
K&N filter
Fulley ported base,
runners,& plenum
Crane AFPR
Hypertech airfoil
Crane 1.6 rockers
210/220 .533/.544 Cam
W/P Torquer heads
Edelbrock TPI Base
Edelbrock TI Runners
Edelbrock 52mm T.B.
TRANSMISSION:
Richmond 3.73's
Auburn posi
B&M Mega shifter
B&M Transpak
Vette servo
B&M 2400 converter
TCI Trans Rebuild
Nitto Drag radials
FUTURE MODS:
The 700R4 is DEAD!!
Neeed to rebuild AGAIN!!
BEST RUN:
12.48 @ 109.23 MPH
(with stock heads,cam,intake,and crappy Pep Boy's tires)
[This message has been edited by Nitro Don (edited January 31, 2001).]
Old Jan 31, 2001 | 09:42 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
I did the same thing Nitro did. Also remember to replace you bump stops.
90 Firebird SSA (Bone stock 3.1)
Everything Below I've added
Engine: Accel Super Coil, 8mm Accel Ignition Wires, 170 Degree Thermostat, NKG Plautum Plugs, K&N Filter, Flowmaster 80
Suspension: Bell Tech Drop Spindles, Edelbrock PanHard Bar, Lakewood Lower Control Arms, Wonderbar IROC-Z, KYB GR2 Struts, KYB Gas-a-Just Shocks, PST Suspension Polygrapite Bushings All Round, 36mm WS6 Front Sway Bar, 24mm WS6 Rear Sway Bar
Brakes: Cross Drilled and sloted Rotors
Appearance: Trans Am Tail Lights, Trans Am Wrap Around Wing, Trans Am 16" Alum rims, Tinted Windows Rear 90% Sides 50%
Interior: GTA power seats, Overhead console, Power windows, Power locks, T-tops, Sun shade, Pioneer P77DH, Uniden radar detector, Intellitronix - Fuel pressure gauge, Transmission temp gauge. (In pods)
Old Jan 31, 2001 | 11:56 AM
Bort62's Avatar
Yeah, Im Considering Doing the Same. How does the Car handle At that Height? Mine is a Sport coupe, So i dont have the ground effects, So I could Go a little Lower.
Have Any Picutures Either Of You ? Woudl be great if You Did
Old Jan 31, 2001 | 12:17 PM
nosaint's Avatar
Car: 1986 Trans Am
first u should check the amount of space from
the fender to the top of the tire. I used Bell Tech spindles for a two inch drop and got the front fender gap down to about half an inch. Im adding 17" tires this summer and then the fit should be perfect. As for the rear, i just went for 1 1/2" springs. It
could use some more but with the Trans am
factory ground effects, It would appear that the rake is going in the wrong direction.
1986 Black & Gold WS6
Trans AM...The Muscle Car Lives
...Its just not at home at the moment...
www.members.home.net/nosaint
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
J-money
Jan 4, 2019 09:45 AM
Formula_88AE
Sep 3, 2015 01:47 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
