BellTech drop spindles
Old Feb 4, 2001 | 01:24 AM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Anyone have these..? How much $$$? Also how about their other lowering parts like the rear springs and shocks - anyone know the price and how well they work...?
Ken
Old Feb 4, 2001 | 03:26 AM
Omar's Avatar
$275 for the 2" drop spindles, and $135 for the rear 1.5" drop springs, and they work great.
1989 IROC-Z 5.7L
Old Feb 4, 2001 | 09:53 AM
Nitro Don's Avatar
Mine is a funny story.A fiend of mine originally bought them for his 89 TA. A few days earlier he just put on his NEW 255/50/16
Comp TA's.He put the spindels in with Hotchkis lowering springs.When he took it for a test drive he found that the cars plastic upper fenderwell was rubbing the hell out of his new Comp TA's.He took them off right away.
The speedshop where he bought them($300) wouldnt take them back cause they were "mounted",so he was out the $300. I begged him for WEEKS to give them to me.Finally after a month he agreed to trade them for a gas genorator that I had sitting around doing nothing that I had gottin for free off of a job site.
I Installed them in my 90 TA that already has a 1.5 spring drop.Knowing that I would have the same problem the 89 had,I removed the plastic wheelwell molding and took a die
grinder to alot of the metal under the fender.I probally cleared another inch or so under the fenders.I rarely bottom out on the
tires/fenders, its mostly the front end that scraps.
It looks good with "NO" gap between the front fenders and the tires
Nitro Don
Old Feb 4, 2001 | 11:01 AM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Wow- thats actually not a bad price at all!
Nitro Don, do you have any pics of your lowered car? it sounds real sweet.
Thanks for the input guys.
Ken
Old Feb 4, 2001 | 11:25 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Mine cost me $250. They are eazy to put on. Also you need an alinement after you install them. Love them.
90 Firebird SSA (Bone stock 3.1)
Everything Below I've added
Engine: Accel Super Coil, 8mm Accel Ignition Wires, 170 Degree Thermostat, NKG Plautum Plugs, K&N Filter, Flowmaster 80
Suspension: Bell Tech Drop Spindles, Edelbrock PanHard Bar, Lakewood Lower Control Arms, Wonderbar IROC-Z, KYB GR2 Struts, KYB Gas-a-Just Shocks, PST Suspension Polygrapite Bushings All Round, 36mm WS6 Front Sway Bar, 24mm WS6 Rear Sway Bar
Brakes: Cross Drilled and sloted Rotors
Appearance: Trans Am Tail Lights, Trans Am Wrap Around Wing, Trans Am 16" Alum rims, Tinted Windows Rear 90% Sides 50%
Interior: GTA power seats, Overhead console, Power windows, Power locks, T-tops, Sun shade, Pioneer P77DH, Uniden radar detector, Intellitronix - Fuel pressure gauge, Transmission temp gauge. (In pods)
Old Feb 4, 2001 | 02:33 PM
nosaint's Avatar
Car: 1986 Trans Am
I have them as well.
700 canadian bucks. I'll agree on the wheel alightment, my wheels were pointing in opposite directions!!!
Lost a little on the turning radius but thats it.
Go for it
1986 Black & Gold WS6
Trans AM...The Muscle Car Lives
...Its just not at home at the moment...
www.members.home.net/nosaint
Old Feb 4, 2001 | 10:18 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
So you keep the original springs up front then..? If so, will it scrape much..?
Thanks!
Ken
Old Feb 4, 2001 | 11:06 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
I see this way. If you have stock springs you should be alright. But there are people out there like me to take it to the limit. My spings are cut and I upgraded my struts to KYB's. Replaced the bump stops also. So I have about .25 inches if that. I had to bend up the sheet metal under the fender well. I try to avoid pot holes and steep driveways.
Old Feb 5, 2001 | 12:09 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Use the dropped spindles, and then get the Morrison Coil over conversion. Really nice.
Then adjust it so the ball joint is about an inch lower then the center of the inner bushing. Add all the caster you can -1/2 camber and have fun
Old Feb 5, 2001 | 12:10 AM
nosaint's Avatar
Car: 1986 Trans Am
I was thinking about getting a stiffer spring that would not change the ride height. Not sure what is different but something changed when the car was lowered.
Stick springs in front, belltechs in back. I have about half and inch of clearance which is good enuff for me.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
