Any of you guys make your own LCA?
Old Feb 18, 2001 | 06:22 PM
UVA3rdGen's Avatar
My friend is up at RIT and he spends his life in the machine shop, he said he could make me just about anything that did not involve casting. Well LCA seemed like an easy enough favor to ask for, my only question is where did you guys find the polyurethane bushings? Or would the solid metal greasable bushings be a better choise for my car?
She is not the fastest thing in a straight line but she sure will stick in the turns.
Hawian Orchid X-SCCA showroom stock 2 time national/ 1 time regional (not with me driving) champ 1LE 92 Z-28
-suspension parts include koni reds, eibach racing springs, weight-jacks, relocated control arms, and the list goes on for suspension; Port & polished TPI system sitting on top a fully blueprinted, balanced and matched race built 305; centerforce II clutch; custom 3.4 auburn rear, custom dual cat exhuast with hooker aerochamber muffler; 1LE fuel pump and gas tank; SS track baer braking system; griffin aluminum radiator; 6 point bolted roll cage with 5 point harnesses; pioneer speaker system; sparco seats, just about as light as you can get a weekly driven 3rdgen.
Old Feb 18, 2001 | 07:03 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
Check out this link: www.p-s-t.com
It will answer all your questions!
Old Feb 19, 2001 | 11:37 AM
Nor Cal Mike's Avatar
The LCA's are a critical suspension component so it has to be done right.If a STB orSFC failed at 70mph, on a busy freeway, chances are life and limb would not be jepordized. IF an LCA came apart it could spell disaster.Since your friend is at a technical institute, I assume that a competent welding and fabrication expetise is available.
IF I were going to build something like that I would first construct a jig to build it in. I would build the jig around a stock LCA. This would keep the center lines of your pivot points in line with OEM specs and would preserve built in offset (if any) that the factory engineers designed in. Double check if left and right LCA's are mirror images by bolting the other OEM LCA into the jig, upside down. If it fits easily and the bolts slide thru without binding then you should be able to construct the other side in the same jig (upside down position).
If your car is a street car, I would stay away from solid bushings. You could use almost any poli graphite bushing that has the right size hole thru the center (I.D.), since you would be custom building th LCA around that particular bushing O.D.
Nor Cal Mike
Red 84 Z28 HO, stock L82 350, L69 carb, intake, and air cleaner.
5 Spd, 3:73 Posi, 1 5/8" SLP headers, 3"cat connected to
stock L69 exhaust, KYB's, homemade SFC's,STB and wonderbar
Some are faster but mine's fast enough.
Old Feb 19, 2001 | 06:09 PM
Get Blown ?'s Avatar
Since he has access to a machine shop I'd try to have the LCAs made of billet aluminum. There's a few aftermarket companies that sell them. Suposidly their 4 times stronger then tubular LCAs. checkout the pictures of Metco's billet aluminum LCAs for ideas at http://www.fasttoys.net/8292fbodysusp.html
1989 Camaro RS LO3 WCT5 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
The posi unit breaker.
Old Feb 20, 2001 | 12:06 AM
UVA3rdGen's Avatar
This is one hightech machine shop to. He has acces to aircraft grade aluminum among other goodies. He makes parts for their Baha racer team also and he is hands down the best fabricator of parts from scratch I know.
Old Feb 21, 2001 | 02:24 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
One quick and easy way to beef up the LCAs are to "box" them. Just weld a plate to the bottom, (open) end and viola!! Much stiffer.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
1992rs/ss
16
Jan 28, 2016 09:58 PM
TheExaminer
Aug 25, 2015 07:34 PM
Street Lethal
Aug 14, 2015 08:25 PM
wruiz
Aug 11, 2015 02:59 PM
NBrehm
Aug 5, 2015 07:57 PM
