Power Steering box - frame damage fix.
Old Feb 21, 2001 | 04:49 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
If you are not familier with the problem, it is when the forces exerted on the frame by the power steering box elongates the holes through the frame that the bolts go through, which adds a lot of slop to the steering.
What kind of shop would I take my car to to fix this problem, and how much do you think it would cost? I dont have any welding skills, and I want to to be done right so it doesnt happen again. Thanks!
Old Feb 22, 2001 | 05:00 PM
JeffT's Avatar
Car: 1991 Z28
Try a body shop or a welding shop. In any event the box needs to come off then clean the mounting area and inspect the cracks. At the end of each crack a small hole needs to be drilled. This is to stop the crack from spreading later. Then weld the hole you drilled as well as the entire crack. Grind the weld down smooth, paint the area and remount the box.
Old Feb 22, 2001 | 05:04 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
the part about the box causing slop is something that i have never heard of, is this a common thing because i have slop in the steering and it was leaking fluid and i took off the belt and i still have slop but obviously no leak
any ideas>
1983 CHEVROLET CAMARO with a 1986
305 C.I.D.V8 BORED .030 OVER
HIGH VOLUME OIL PUMP
FLAT-TOP PISTONS
MILD CAM
3" CAT BACK EXHAUST W/ FLOWMASTER MUFFFLER
KEYSTONE CLASSIC WHEELS.
B&M RATCHET SHIFTER
STAGE THREE SHIFT KIT
(she'll spin em into third)
CHECK OUT MY SITE http://www.fbody.com/members/bigdaddyshawn/
MUSTANGS SUCK
Amillionoh7
May 24, 2020 08:01 AM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
