Questions about rim offset and boxing lower control arms.....
Old Feb 25, 2001 | 11:48 AM
firebird305's Avatar
Yesterday i went and brought 2 rims,Nothing fancy,Just something to mount some slicks on.they look like the stock rims that would come on a chevy s-10. The rim size is 15 by 7. the rims that are usually on the car are 14 by 6,and when i put on the 15 by 7s,They don't seem to slide as far back on the wheel studs as the 14 by 6s. Is this because of the backspaceing of the 15 by 7s? Also,I read a post where someone said you could box your lower control arms by welding a plate to the bottom. What kind of metal shoud you use and could a exaust shop do that type of work? Thanks for the help.
82 firebird with 305H.O.,Block bored .30 over,Keith black hyperutectic flat top pistons for 10 to 1 compression,Turned crank,Magnafluxed connecting rods,Melling H.V. oil pump,and double roller timeing chain,Ported and shaved heads w/3angle valve job,Z-28springs,Summit push rods and comp cams magnum roller rockers,Ported Edelbrock performer r.p.m.intake,Carter 625 afbcarb,Accell spark plugs,wires,and H.E.I.super coil,Heavy duty cap and rotor,Clevite performance cam with 450-460 inches of lift,Comp cams lifters,700r-4 tranny rebuilt with trans-go rebuild kit,corvette servo,New torQue converter,Flowtech headers,Flowmaster muffler,3.73limited slip rear end,Energy suspension bushings from front to rear,Energy suspension tranny mount,New center link,ball joints,trans-am steering box,ASP power pully.
Old Feb 25, 2001 | 04:23 PM
ede's Avatar
ede
i have my slicks mounted on a set of weld drag stars with 4.5" offset. use mild steel to box in the LCAs, i used 16ga mostly because thats the thickest steel my cousins shear could cut. i'd say about any one with a good welder could box them for you. i used stick machine to do mine. when i was done welding i needed new bushings. i pressed in a set of ES poly bushings.
ICON Motorsports
1st & 3rd
1992rs/ss
Jan 31, 2025 05:10 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
BikeFarm
Aug 11, 2015 11:35 PM
