manual steering help
Old May 31, 2010 | 11:13 AM
frankmurphy's Avatar
ok so im switching to a manual box from an 85 s10, anyone have a part number on the pitman arm i need? stock firebird one has to big of a hole, s10 arm doesnt have the same bend, any info would be great. thanks- frank
Old May 31, 2010 | 12:53 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: manual steering help
If your stock pitman arm won't fit it, you probably have the wrong box.
Does your S10 box have the 4-bolt top cover?
Old May 31, 2010 | 01:00 PM
Project-RS's Avatar
your stock arm will fit. i went with a 85 s-10 manual box with 4 bolt pattern. i know the 3 bolt ones might not fit.
Old May 31, 2010 | 01:35 PM
My box is a 3 bolt pattern, i guess i will try to get a 4 bolt pattern, anyone have a part number for the 4 bolt box?
Old May 31, 2010 | 02:47 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
For $385.70: http://www.napaonline.com/Search/Det...+50030+2030040
I have one of the correct ones for sale if you're interested, $80 shipped. Already has the correct pitman arm on it.
Old May 31, 2010 | 07:39 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
3 bolt top cover is 83 and older. Although it can be made to work, it's not as easy to adapt as the newer 4 bolt top cover versions. It's better to find a 4 bolt top cover version which is a direct fit.
Old May 31, 2010 | 07:58 PM
thanks everyone.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
