Tech specs on brake line fittings.
Old Mar 3, 2001 | 03:08 AM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Does anyone know of the technical specifications for the brake line fittings on a 1986 Camaro Sport Coupe. This has rear drum brakes. The fittings are for 3/16" lines (all the same size fittings) and 2 fittings for a 1/4" line (both the same size). All I know is that they are metric!
Thanks.
Old Mar 3, 2001 | 08:50 AM
ede's Avatar
ede
i'm not sure the thread is metric, the flare is called a "european flare" or something like that. as you can tell the nut has a unthreaded part for it to line up in the mateing part before the threads engage.
ICON Motorsports
1st & 3rd
Old Mar 3, 2001 | 04:21 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Actually, its called an "ISO Flare". As for the size, your right it is metric, but I don't know the exact size off hand.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Mar 4, 2001 | 06:21 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
size is "M1.0"
82Z 305 w/comp 270 magnum cam,holly.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
