Urethane front end kit, Is it worth it
Old Mar 5, 2001 | 01:26 PM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
I have over 213,000 miles on my 86 IROC. It needs an alignment and tires, so I figured I should do it right and replace the bushings, tie rod ends and such while I am at it. I have seen ad's for a complete front end kit from PST for $159. I have also heard that they squeek. I don't like spending money twice so I want to do it right. Are the Energy suspension bushings worth spending more on? I appreciate your opinions. THANKS!!
1986 IROC LG4 "Bone Stock" (for now)
Old Mar 5, 2001 | 09:25 PM
ROCHEAD's Avatar
I just took my car out of its shell for a bit to see if there is a difference. I changed ALL my bushings and man what a diff. Very tight and squeek free. I put Energy Suspension polyurethan bushings all around. New tie rods in and outer. I put the master kit for 82-92 cars. Endlinks everthing is new and it was worth every pennie. I don't know about PST products but if your gonna go the ES way. Make sure everything is dirt free and tottally clean. When i took the front end apart i found out that i had a 1 1/2 sway bar. heheheh i had to machine a 36mm sway bar bushing ti make it fit right. Anyways its your choice but if want to do it right. Id go ES all the way.
Old Mar 5, 2001 | 10:08 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I've had the PST kits twice and the ES once. ES squeaks far more than the polygraphite PST kit.
"A lawyer with his briefcase can steal more than a hundred men with guns."
-Mario Puzo
Old Mar 6, 2001 | 09:18 AM
Car: 1986 IROC
Does Energy Suspension make a grapite kit like PST does?
Old Mar 6, 2001 | 11:02 PM
ROCHEAD's Avatar
maybe you didn't grease the bushings enough cause mine don't squeek nothin. Not a peep.
Old Mar 8, 2001 | 09:12 AM
Car: 1986 IROC
What kind of grease should I use? On which bushings? (I am doing front and rear everything) THANKS
Old Mar 8, 2001 | 10:35 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i have the greasable energy suspesion componets on my car and theydon't squeek at all.their a better quility part than PST in my opinun
1991 banditt2 #130 of 600
<A HREF="http://clubs.yahoo.com/clubs/streetdawgracing" TARGET=_blank>
http://clubs.yahoo.com/clubs/streetdawgracing</A>
http://y42.photos.yahoo.com/tonysams72.
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation
1992rs/ss
Jan 31, 2025 05:10 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
bellez77
Sep 5, 2015 08:39 PM
