Squishyness and Brake steer.
Old Mar 3, 2001 | 11:56 PM
Bort62's Avatar
Ive got the 85 front Disc/rear drum setup, Completely Stock.
The pedal is a Lot More squishy than I would like it to Be. So I went through and started fixing things.
Ive replaced all the pads/shoes ( first thing)
I also replaced the front lines ( helped some )
Didnt Turn the front Rotors yet, But they look to be A-ok.
Flushed all the fuild, By pouring new in whilst the brakes were slowly pumped with the bleeder open on each wheel, One at a time, Till Clean fluid came out.
Bled them all the way around a few times, from farthest to closest to the MC.
Never let any air into the MC while Flushing it, But when I swapped the soft lines I just unscrewed them, and put the new ones in. I bled the brakes after Obviously.
Did I do something wrong There?
I also have Not replaced the softline to the Rear yet, So this may have something To Do with it.
It feels alot Firmer sometimes than others.
Lastly, I occasionally get Brakesteer, And Not to any particular side, It alternates.
Usually If I start to brake, I will feel steer. Then I let off and brake again, and its fine.
any suggestions ?
Thanks for any help You can provide
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Mar 4, 2001 | 07:50 PM
Bort62's Avatar
BTT pls.
Old Mar 5, 2001 | 10:20 PM
Bort62's Avatar
BTT< ths is the suspension and BRAKE forum, isnt it ?
Old Mar 6, 2001 | 08:59 AM
RGZWS6's Avatar
Bort,
I feel your pain. I currently have just about the same problem as you. Originally, I had terrible brake steer to one side. I replaced the calipers with rebuild ones and that did not help. I then changed both rubber hoses for the front brakes and that brings me to the symptoms you have. The brake steer is not as bad, but still evident. I think I may need to re-bleed my lines. I also need to tighten my bleeder screw because once under hard braking, fluid spewed. Horrible feeling to lose pressure when trying to stop! Next project is a rear brake job.
I did the exact same swap on my 86 Cutlass Ciera and, I hate to say it, it stops WAY better than my Formula.
89 Formula 305 TBI
160* stat, 200* fan switch, K&N, Headers, 3in Flowmaster (hollow cat) back, pullies, 1.6 full roller rockers, B&M trans cooler, home-made ram-air
3.73 Richmond gears and SLP Zexel Torsen Posi (waiting for install)
Old Mar 6, 2001 | 10:13 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Bort, that's the right way to replace the soft hoses in the front. In fact if you didn't replace those hoses, I would've said you should. Maybe you're getting the brakesteer from a problem with the rear brakes?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 6, 2001 | 11:37 AM
Bort62's Avatar
Possibly Tom, Ill replace the Rear Softline this weekend IF I get a Chance, and re bleed all the way around.
Its really quite annoying tho, My car stops great sometimes, and others it dosent. Is this just the inherant ****tyness of the stock breaks on a Sport Coupe, Or is there still something I need to Fix ?
Thanks for the Reply's.
Old Mar 7, 2001 | 10:44 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
<font face="Verdana, Arial" size="2">Originally posted by Bort62:
Usually If I start to brake, I will feel steer. Then I let off and brake again, and its fine.</font>
Hey, that's weird... I just noticed this sentence of yours from your first message. I believe I still have air trapped in my master cylinder somehow. If I hit the brakes (easy or hard, doesn't matter), release them, and hit them again, the brakes work better! Are these related? I only get brake steer under a verrry hard braking condition tho; and that's mainly because my left rear disc caliper isn't working that well.
Old Mar 7, 2001 | 11:53 AM
Bort62's Avatar
Sounds very similar Tom.
I also Notice that If I Accelerate fast off idle, and then brake hard w/in a few seconds, the brakes feel like they almost go to the floor.
Air in the MC huh ?
how Do we Bleed it out ?
Thanks For the help
Old Mar 9, 2001 | 12:50 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'll have to try that (accelerate hard from idle, hit brakes, watch pedal) this weekend, I'll let you know what happens.
A bleeder kit... the Haynes book gives details on bleeding the thing, but it's such a pain in the *** ! I was working on a home-made pressure bleeder, like the ones a brake shop would have, but stopped as soon as it got cold outside.
In a nutshell, you'd have to remove the line closest to the firewall (it's for the front brakes) from the m/c. Then you'd run clear tubing from the port back into the m/c reservoir. Then you slowly pump the brakes to the floor, wait 10 secs, release, wait 20 secs (for the quick-take-up-valve to fill), then repeat; this is done until no air bubbles are seen anymore in the clear tubing. Then you remove the tubing, attach the hard line back to the m/c, and repeat for the front-most m/c port (for the back brakes). Then you bleed the whole damn car again.
Old Mar 9, 2001 | 07:18 PM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
Hey Tom, I'd like to point out that if you do submerge the end of the clear tubing back into the MC, you'll still have a little air left in the system even after the bubbles disappear. The reason being that air takes a pretty long time to get out of brake fluid. If you look at it closely you'll notice really tiny bubbles in there. What I usually do is bleed the brakes into a separate container, and keep refilling the MC with new fluid. The old fluid can be reused after 1 day if it is still clean. Hope this helps solve your problem. BTW, bleeding brakes the old fashioned way is a two man job that a real PITA because both people need to know exactly how to do it, but it is the best way. I wouldn't really trust speed bleeders or such stuff but that's just me .
'88 IROC 305 TPI
Crappy 700R4 slushbox
Gutted airboxes
180 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel (gotta luv it)
Ram-air setup coming soon
Flowmaster muffler (puke)
Taylor SpiroPro wires
Accel cap and rotor
Ported plenum
Kills: '94 Z28, Olds Aurora V8, bunch of Mustangs, T-birds, ricers, and others who assumed a 12 year-old car would be too slow.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
