wheel balancing
Old Mar 9, 2001 | 03:47 PM
GearHead1973's Avatar
wheel balancing
I had all 4 wheels balanced on my camaro which are Z28 aluminum wheels. One is bent and the guy at the tire shop had to put 5 ounces on one side and 1 ounce on the other. If I put this one in the rear will I have any problem.
Old Mar 9, 2001 | 08:11 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
<font face="Verdana, Arial" size="2">Originally posted by GearHead1973:
</font>
More than likely, yes, depending on how bent it is. Five ounces on one side? That certainly isn't good, and shame on him for even bothering w/ a bent rim.
He should have at least tried to dismount the tire and move it around to acheive the best balance. 5 ounces on one side is alot, thats more than I like to do on the whole wheel.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
--&gt;14.97 @ 94.9 MPH&lt;--
'97 Bonneville SSE
Old Mar 9, 2001 | 08:22 PM
buddman91rs's Avatar
which year Z28 rims? if you have 91 92 rims then you cant move them back to front without dismounting the tires from the rims.
1991 RS LO3
mods: 14" chrome air cleaner, straight-piped after cat exhaust with one chrome dual tip on the left side.
future mods: headers, removing smog equipment, and as many cheap mods as i can find
aol s/n: budman8503
SUCKING GAS AND HAULING *** -The American Dream
Old Mar 9, 2001 | 08:42 PM
The wheels are off a 84 Z28. I called the shop that balanced the wheels and they said if I get another wheel they will mount and balance the tire no charge. I located a wheel at a salvage yard for $25. I thought the wheel would be expensive thats why I wanted to know if I could use it but now I will get it fixed right. Thanx.
Old Mar 10, 2001 | 07:10 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Good choice.
South East Thirdgen
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
db057
Apr 28, 2019 07:45 AM
Chiknhawk
Wheels and Tires
Jan 29, 2017 10:19 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
roysatikas
Sep 7, 2015 08:08 PM
scottmoyer
Sep 7, 2015 07:06 PM
