e-brake (parking brake)
Old Mar 14, 2001 | 05:13 PM
v6-3.1's Avatar
I have a 1990 camaro RS 3.1L.
when I first brought the car the E brake did not work. when Im inside the car I can pull it all the way up and nothing will happen to it. I recently took out the panel and noticed that the cable is attached to it. how do I adjust it?
Old Mar 14, 2001 | 06:58 PM
Tom Batts's Avatar
Old Mar 14, 2001 | 09:24 PM
v6-3.1's Avatar
My car is a 1990.I dont think any of this applys to my car
Old Mar 15, 2001 | 03:20 AM
Mo's Avatar
Mo
I have this problem too, BUT only sometimes (???) so if you figure out a fix for it I would sure be interested in hearing about it.
thanks
Oh yeah, I heard there was a way to adjust it under the car somewhere, but I don't know if that is for certain years or all years, I haven't been home yet to check that out...1 more week .
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
Old Mar 15, 2001 | 09:28 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, V6-3.1 has drum brakes in the rear, not discs...
The adjuster's easy to find, it's under the car and above your driveshaft. In fact it's almost directly under the console. That's where the one cable (from the e-brake handle) splits into two cables (to each drum brake).
You need two wrenches, some wd-40, and safety goggles (to keep wd-40 & all the dirt out of your eyes). Use one wrench to "back up" the center cable (from e-brake handle)- put the wrench on the bolt where it attaches to the cable. It's cut like a square for a wrench to fit on it. This keeps the cable from spinning. Then, use the other wrench to tighten/loosen the nut. It's an easy job but a messy one.
The Haynes 82-92 Camaro manual (found at stores like Pep Boys & etc) covers this adjustment procedure.
It's also possible that your drum brakes aren't adjusted correctly... and I think you had a problem with them before, right? If the brake shoes are too far away from the inside of the drum, that means the adjuster's frozen up. You'd have to turn the star wheel to move the shoes out... it's a pain in the but. Adjustment for drum brakes happens when either (A) you use your E-brake when parking the car, or (B) you hit the brakes HARD when going in reverse.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
LittleFranks
Sep 17, 2015 12:22 PM
