rollcage
Old Mar 14, 2001 | 05:40 PM
kjatsi's Avatar
rollcage
I'm thinking of installing an 8 point cage, I would like some ideas on brands? also if I run a cage should I still run sub. frame connectors?
Old Mar 14, 2001 | 06:04 PM
ede's Avatar
ede
for brands, jegs, alston, s&w, morrison, and many others. yeah you can still run SFCs
ICON Motorsports
1st & 3rd
Old Mar 14, 2001 | 08:47 PM
RARE-ROC-Z's Avatar
s&w racing.. and yes you should still use SFC's..i am doing the same thing.. the cage from S&W is only 149.99
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 7.5" 10 Bolt 3.23gears
Bright Red Hardtop/ Grey Custom Interior
5,507 IROC's; 2,415 5.7L IROC's Produced in 1990
DAILY DRIVER: 1991 S10 2.5L/5SPD WITH CAMARO RIMS
Old Mar 15, 2001 | 09:34 AM
Nor Cal Mike's Avatar
Better yet, figure out a way to tie the cage and the SFC together. Since most SFC's follow a path just inside the rocker panel, they pass right under the hard (attachment) points of the cage. In most cases, it would be relatively easy to run U bolts around the SFC, up through the floor and through the 6"x6" mounting plate of the cage. Install a spacer or shim between the SFC and the floor, tighten the U bolts which would sandwhich the whole package together and wha la, the system becomes a very ridged truss.
Nor Cal Mike
Red 84 Z28 HO, stock L82 350, L69 carb, intake, and air cleaner.
5 Spd, 3:73 Posi, 1 5/8" SLP headers, 3"cat connected to
stock L69 exhaust, KYB's, homemade SFC's,STB and wonderbar
Some are faster but mine's fast enough.
[This message has been edited by Nor Cal Mike (edited March 15, 2001).]
Hill1513
Sep 19, 2015 04:15 PM
TexasMaro
Sep 15, 2015 06:50 PM
silentkillzr
Mid-West Region
Aug 16, 2015 09:22 AM
xlwhellraiser
Convertibles
16
Oct 4, 2007 06:47 AM
86WhiteIroc
Jul 26, 2006 03:10 PM
