Top strut nut INSTALLATION problem
Old Jun 11, 2010 | 04:07 PM
algershick's Avatar
I've finally got both of my struts installed and the car back on the ground. I'm trying to tighten the top nuts of the struts.Why on earth would the top nut be extremely hard to thread onto the brand new strut?
Strut/nut was difficult from about the 2nd thread, and continues to require more force the further I tighten it down. I am to the point that I'm afraid I'm going to break something. I got it to within 1/4" of being seated properly on the bearing plate. I backed it off a little while later to check everything out-- the nut was too hot to hold just from the friction of REMOVAL. What's the deal? Both sides are equally difficult to tighten.
Old Jun 11, 2010 | 04:12 PM
Stephen's Avatar
Car: 87 GTA
Re: Top strut nut INSTALLATION problem
Chances are that it isn't tightening and getting hard to turn, but rather....The strut shaft is spinning & turning with the nut.
Old Jun 11, 2010 | 04:50 PM
algershick's Avatar
The shaft isn't turning, I've got ahold of the nut with a wrench/cheater bar and a socket/ratchet on the 10mm hex head of the strut itself.
Old Jun 11, 2010 | 04:54 PM
Stephen's Avatar
Car: 87 GTA
OK......
Wrong sized nut then? Maybe the manufacturer made the new struts with the wrong thread size, just a hair off? Maybe standard vs metric? Or are these the nuts that came with the struts?
Old Jun 11, 2010 | 05:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Originally Posted by Stephen
OK......
this
you may have received the wrong nuts.
Old Jun 11, 2010 | 06:46 PM
lonesomeloser's Avatar
Car: 1983 Z28
Are they nylon-lined nuts?
Old Jun 12, 2010 | 12:25 AM
algershick's Avatar
They are indeed the nuts that came with the struts in the box, no they aren't nylon lined
Old Jun 12, 2010 | 11:49 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
that still doesnt mean they are right. if they are getting tight after a thread or two, they are the wrong thread pitch. do the old ones fit?
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
mustangman65_79
Aug 8, 2015 12:07 PM
