Unequal wheel to outter tie rod clearance on each side?
Old Jun 12, 2010 | 11:44 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
On my drivers side i cant fit my pinkie finger between the wheel and tie rod. on the passenger side i can almost fit my thumb between the wheel and tie rod. not sure why or if its spouse to be that way but it is on mine, i checked the rims both are fronts no spacers etc, same outer tire rods on each side, check torque specs on the linkage everything's nice and tight turns fine, but the tie rod to wheel gaps are different
Old Jun 12, 2010 | 11:49 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Unequal wheel to outter tie rod clearance on each side?
the steering arm on the spindle decides where the tie rod sits, if its bent it could be off, maybe the hub/rotors are different, maybe the wheels are slightly different offset, bent, ect ect ect.
Old Jun 12, 2010 | 11:54 AM
FueledSoul's Avatar
yea i realize there are a lot of variables. im kinda leaning towards a bent spindle.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
kah992
Aug 19, 2015 02:55 PM
wruiz
Aug 11, 2015 02:59 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
