Are all A-arms the same
Old Jun 13, 2010 | 08:04 PM
rogslayer's Avatar
Car: 92 Camaro RS
Engine: 3.1
As the title says, are all A-arms the same on 82-92 models, just wondering because I got one off an 84 to put on a 92. I'm assuming they are just wanna double check.
Old Jun 13, 2010 | 08:50 PM
Guest
Guest
Posts: n/a
Re: Are all A-arms the same
From what I know, And I could never confirm this because I never personally checks but I think the steering stops riveted onto the a-arms are slightly different posistioned between the 15" factory wheel cars and the 16" factory wheels cars. I put 16" factory IROC wheels on a factory 15" RS car and the wheels would rub until I welded a little more material onto the factory a-arm stops.
Old Jun 13, 2010 | 08:54 PM
rogslayer's Avatar
Car: 92 Camaro RS
Engine: 3.1
think A-arms from a 14 inch wheel car to a 15 inch wheel car would throw off the end links any?
Old Jun 13, 2010 | 08:58 PM
Guest
Guest
Posts: n/a
No, That should all line up.
Sway bar links are always a little cockeyed. Best to install both sides just barely together first, making sure you have both sides attached before you start tightening either side.
Often also people use slightly shorter endlinks and suffer from this result also. Longer links help with better alingment, but too long of links will cause contact of the swaybar into the chassis during articulation of suspension function
Old Jun 13, 2010 | 09:32 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
According to the Parts and Illustration Catalog, Dean, you're correct, the two are different.
Example:
Stop, Lwr Cont Arm-RH (82-84) (85-87 Exc 16" Whl) (88-89 Exc Z28) (90-91 Exc 16" Whl).
Stop, Lwr Cont Arm-RH (85-87 W/16" Whl) (88-89 W/Z28) (90-91 W/16" Whl)
Moreover, the Bumpers are different as well:
Bumper, Lwr Cont Arm (1982-84) (1985-87 Exc FEZ) (1988-91 W/15" Whl) P/N 10068783
Bumper, Lwr Cont Arm (1985-87 W/FEZ) (1988-91 W/16" Whl) P/N 14089443
JamesC
Old Jun 13, 2010 | 09:35 PM
rogslayer's Avatar
Car: 92 Camaro RS
Engine: 3.1
well the passenger side lines up, but the drivers side is so far off the bumpstop on the a arm will hit the sway bar
Old Jun 13, 2010 | 11:16 PM
Guest
Guest
Posts: n/a
Example:
Stop, Lwr Cont Arm-RH (82-84) (85-87 Exc 16" whl) (88-89 Exc Z28) (90-91 Exc 16" whl).
Stop, Lwr Cont Arm-RH (85-87 W/16" whl) (88-89 W/Z28) (90-91 W/16" whl)
JamesC
Thank you James, I have never seen that confirmed.
Old Jun 13, 2010 | 11:17 PM
Guest
Guest
Posts: n/a
Sound to me like you bent the swaybar
Old Jun 13, 2010 | 11:18 PM
rogslayer's Avatar
Car: 92 Camaro RS
Engine: 3.1
i tried another one it lines up the same
Old Jun 13, 2010 | 11:30 PM
Guest
Guest
Posts: n/a
Can you try taking apart the connected side and starting by attaching this side first? see if that renders the same problem on the other side.
Old Jun 13, 2010 | 11:38 PM
rogslayer's Avatar
Car: 92 Camaro RS
Engine: 3.1
I've tried hooking each side up first, the drivers side always comes out having a bad angle on the endlink, this post will tell why I'm having the problem I've replaced most of the parts https://www.thirdgen.org/forums/susp...ot-lining.html
Old Jun 13, 2010 | 11:47 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Since it was brought up I noticed this too. From the Global West site, they list different part numbers for the lower arm bushings with the cut off being mid year of 1983.
http://www.globalwest.net/1982-02_Ca...m_bushings.htm
Part# 1021 ( fits 1982 to mid 83) $150.41 per car
Part# 1022 (fits mid 1983-92) $150.41 per car
Old Jun 14, 2010 | 06:59 AM
tom camaro's Avatar
Car: 83 Camaro
Engine: LT1 SD Mode 30lb/hr
The 82-83 ones have a smaller bushing. The are all the same bushings from then out.
Old Jun 14, 2010 | 11:19 AM
Guest
Guest
Posts: n/a
Lets conclude the given facts-
'82- '83 1/2 A-arms: small ear bushings/15" wheel stops
'83 1/2-'92 A-arms: Large ear bushings...two types of stops/ a) 15" wheel stops, and b) 16" wheel stops
This concludes there are 3 types of factory A-arm options if one were to get something out of a salvage yard.
Old Jun 14, 2010 | 11:41 AM
tom camaro's Avatar
Car: 83 Camaro
82-83 1/2 have a busing diamater of 1 5/8 "
83 1/2 92 Have bushing dia of 1.915" according to my notes from Global West.
Old Jun 14, 2010 | 01:15 PM
rogslayer's Avatar
Car: 92 Camaro RS
Engine: 3.1
ok thanks all
Old Jun 14, 2010 | 11:09 PM
Scorpner's Avatar
Engine: V6, V8
Thanks for the info! Was that on their website or something you have on hand? Just curious since I was looking on the website and didn't see anything specific like that.
Old Jun 23, 2010 | 11:02 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Ok guys. Im desperate and I need help as in tonight because tommorrow (Thursday) Im going to hit the junk yard early in the morning. So my understanding is that the 16" (85-92) wheel has the large ear right? So then does the 92 RS have 16" wheels? In otherwords, Is my 86 IROC's front control arrns the same as the 92 RS's control arm?
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
92projectcamaro
Sep 24, 2015 08:09 AM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
