How many of you use SFCs as jack points
Old Mar 17, 2001 | 05:36 PM
theformula's Avatar
just wondering
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March alt. pulley, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (5400rpm limit),Holley 9mm wires,Ac delco R43ts plugs,stock chip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Mar 18, 2001 | 05:21 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I do. at first I did not but, It just seems like a better place because the factory spots just are not as strong. but, when on the lift I use the factory spots due to the frount pass side.
Old Mar 19, 2001 | 01:17 PM
Jza's Avatar
Jza
I do on both cars, but on the convertable I use a long 2x4 to spread the load, even though it's SFCs have "jack points" built into them.
Old Mar 19, 2001 | 02:22 PM
Matt_91RSTPI's Avatar
I do. It is soooo much easier. The front of my car is too low for the jack to slide under and reach the front crossmember. As a note, I have the Kenny Brown SFCs.
Matt
Old Mar 19, 2001 | 02:30 PM
theformula's Avatar
Are kenny browns tubular? Is it safe to jack up on tubular SFCs?
gta892000
Aug 11, 2019 11:16 AM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
z28joe2
Sep 28, 2015 05:54 PM
roysatikas
Sep 22, 2015 08:15 PM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
