When installing lcas does it matter if the car is at ride height or in the air?
Old Mar 16, 2001 | 08:35 PM
86Trans Am's Avatar
I know it should be at ride height to tighten the bushing bolts but what about installing the lcas, does it matter if the car is on stands vs a drive-on lift.
thanks
do you know how much torque is supposed to be on the lca bolts?
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old Mar 16, 2001 | 08:56 PM
RARE-ROC-Z's Avatar
hey if you drive on the lift you wont be able to get the LCA off. and it doesnt matter if the car is off the ground. you can still install. and i dont know the torque specs sorry no help there.
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 7.5" 10 Bolt 3.23gears
Bright Red Hardtop/ Grey Custom Interior
5,507 IROC's Coupes/Ttops; 2,415 5.7L IROC's Produced in 1990
DAILY DRIVER: 1991 S10 2.5L/5SPD WITH CAMARO RIMS
Old Mar 16, 2001 | 09:18 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Torque should be around 90 ft-lbs
ICON Motorsports
Old Mar 16, 2001 | 10:24 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
yea dude..it does. I could get the bolts off but not on which was a pain in the *** , had to screw with it for ever. Do it level and it goes right on
" I'd rather run last in a full out race, than to NOT run at all ".
Old Mar 17, 2001 | 12:53 AM
SillyWabbit's Avatar
Car: '91 Formula
So you're saying that you need to lift the car to get em off, but lower it back down to put em back on?
Old Mar 17, 2001 | 02:56 PM
james_fearn's Avatar
don't fully tighten the LCA bolts until the car is on the ground with the suspension loaded. Just leave a little play in the bolts until you drop the car. Your bushing will reward you for doing so. It's easier to put the car on stands and a jack under the center section because it's easier to manipulate the rear easier. Also do only one side at a time. It will save you a lot of grief.
James
Old Mar 20, 2001 | 12:13 PM
86Trans Am's Avatar
Why would i not be able to get the lca off on a drive-on lift, the front of the lca came off fine during the first attempt at installing my sfc's
1986 Trans Am
305 TPI
1992rs/ss
Jan 31, 2025 05:10 PM
Linson
Aug 21, 2015 02:12 PM
bryan623
Aug 10, 2015 11:33 AM
drathaar907
Aug 6, 2015 04:20 PM
NBrehm
Aug 5, 2015 07:57 PM
