Bolt in roll cage
Old Mar 20, 2001 | 08:34 PM
lexussc94's Avatar
Bolt in roll cage
Does anyone know where I can get a bolt in roll cage for the third gens?
Old Mar 20, 2001 | 09:10 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
jegs makes a bolt in kit for there cages, i think it's an extra 50 bucks. Not sure how much your gonna want it though, it's not nearly as rigid as a welded cage, and over time, the bolt holes will elongate, and basically make the cage no more than 100 pounds of baggage in the car. hope this helps you out...
My 1986 Z28 and more!!
85 IROC w/ 1364 miles!
R.I.P Dale Earnhardt
Old Mar 20, 2001 | 11:46 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Although the bars can be bolted to the floor as per NHRA specifications (get a rule book), a bar that is bolted together (front and rear braces to main hoop) is only cosmetic and offers no strength or rollover protecting. It also won't pass a tech inspection if your car runs quicker than 11.99 in the 1/4
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
Jlanz55
Sep 6, 2015 07:28 PM
FormulasOnly
Sep 6, 2015 10:42 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
