Clunking noise from LCA's?
Car: 1992 RS
Engine: 406 Stealth Ram
I had BMR Fab. LCA relocation brackets installed, along with BMR LCA's and a Panhard bar yesterdy. The LCA reloc. brackets are weld-on's. The car seems to have more bite than it did before, but now I have fairly loud clunking noise that seems to be coming from the LCA's. I tried to move them around (LCA's, brackets, and panhard rod), but every thing feels snug. Any suggestions as to what happened? Thanks!
Check your sway bar mounts. They may have snapped loose. Mine gave way turning a corner once. You really cant see that they have broken unless you are looking for them. With the car in the air, it becomes more apparent. Check it out.
89 Formula 305 TBI
160* stat, 200* fan switch, K&N, Headers, 3in Flowmaster (hollow cat) back, pullies, 1.6 full roller rockers, B&M trans cooler, home-made ram-air
3.73 Richmond gears and SLP Zexel Torsen Posi (waiting for install)
89 Formula 305 TBI
If the rear sway bar (yes) has given way, check the end links at each end. All it is, is a bolt with bushings sandwiching it to the body. The bolt usually rusts and breaks, leaving the sway bar end smacking up against where it was originally attached.
Any parts store will carry the replacement kits. They aren't performance bushings though. More than likely they will be OEM. Cost reflects that; usually in the $15 range to replace both ends. Be sure and replace both ends even though only one may have broke. I believe the kit comes with enough to do both ends but I may be mistaken. Its been a few years. SUPER EASY install!!
89 Formula 305 TBI
[This message has been edited by RGZWS6 (edited March 15, 2001).]
89 Formula 305 TBI
Car: 1992 RS
I havent had a chance to take a look at what is wrong (I was on vacation, I posted from the hotel room!), but I am sure it isnt the rear sway bar. The day the noise started, I took my car in to get new rear tires, and I checked it out while it was on the lift. I glanced at the swaybar, and it lookd like it was fully attached. I am taking it to the shop tomorrow to see if they can see anything wrong. Thanks for the help, though.
Almost forgot, I got poly/poly bushings. It isnt a squeaking noise, but a loud clunk, kinda frightening when driving 80 mph down the freeway!
[This message has been edited by Scott_92RS (edited March 16, 2001).]
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Sure it's not a broken trans mount and worn torque arm bushing? I had a friend's car that had that problem, similar to what you're describing. If it is torn, get a polyurethane mount...they never tear.
Car: 1992 RS
UPDATE:
I took my car back to the shop that put on the LCA for me, and the guy said the jam-nut had come loose. He didnt know why that was causing the clunking, though. He tightened it up, and everything was fine. I drove home, and when I turned onto my street, the clunking returned. I am assuming its the same prob, so I am just going to tighten it up, but how can I get this to stop? I dont want to use LocTite, it will defeat the purpose of the adjustability. Any suggestions?
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
It sounds like a broken tranny mount to me. I have the Global West lower trailing arms with the spherical bearings and they do clunk some, but not on the highway...
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
sjorgens
Oct 1, 2015 07:54 PM
luvofjah
Sep 26, 2015 08:28 PM
