Proportioning Valve Question.........
Old Mar 24, 2001 | 10:46 PM
Customkitt's Avatar
I have a 1984 Pontiac Trans AM, I am looking to increase braking power, if i buy a Wilwood Proportioning Valve, can i remove the stock Proportioning valve and replace it with the Wilwood, or do i need to keep the stock one and use that in conjunction with the Wilwood ?
Ponys can run, but Birds can fly !!!!
Old Mar 25, 2001 | 12:47 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I don't think an adjustable prop valve is going to do anything to increase your braking power, it'll just let you vary the bias between the front and rear brakes.
Old Mar 25, 2001 | 05:04 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
If you want to increase your braking power. You will need to increase you brakes. ala 1LE or sometimg similar.
82Z 305 w/comp 270 magnum cam,holly.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
