Installing new Center Link
Old Mar 25, 2001 | 05:56 PM
MY87ROC's Avatar
Car: 87 IROC
Engine: 5.0
My question is, my manuel shows a special tool to install the inner tie rod to the center link, it is supossed to seat the flare on the inner tie rod to the center link
basicly it looks like a big nut to pull the flared end through, my ques., is this necessary, will the nut that holds the two together be able to acomplish the samething
Thanx for any help.
TPIS airfoil,relocated MAT,AFPR,TB h2o bypass
March Underdrive Pulleys
otherwise stock 5.0TPI
700r4, 9 bolt 3.23 g92 axle, 4 wh. disc brks.
Old Mar 25, 2001 | 07:47 PM
92TRANSAMWS6's Avatar
I needed no special tools when I replaced my center link. The only tool I think you could possibly need is a PICKLEFORK and that's just to remove the tie rods/idler arm/pitman arm from the center link.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
formula_novice
Aug 18, 2015 08:48 PM
sonu1975
Aug 11, 2015 08:38 AM
