Who else has this problem?
Old Mar 15, 2001 | 03:59 PM
Apone's Avatar
Car: 1991 GTA
Whenever I have to brake, my car pulls rather violently, especially on uneven or bumpy roads. I plan on using all SPOHN products on my car this spring to fix this problem, but I wanted to know if anyone else has had this similiar problem...
Old Mar 15, 2001 | 06:19 PM
ede's Avatar
ede
i believe you have a problem with your brakes not in the suspension, or any of it's parts. look for a caliper not working when you apply preasure to it.
ICON Motorsports
1st & 3rd
Old Mar 20, 2001 | 08:29 PM
Matt86Z's Avatar
Don't know if you've worked it out or not, but replace both front flex hoses.
Old Mar 26, 2001 | 09:51 AM
88firebirdTBI's Avatar
it does the same thing in my car
Steve
88 Firebird TBI,TH700R4 - Open Element, Cat Delete, K&N filter 14*4 element
1/4: 16.1@85.7
Old Mar 26, 2001 | 02:39 PM
PR's86Z's Avatar
Usually if you are driving down the road and you apply the brakes, if the car pulls to one side or the other it is probably in the brakes. If it pulls because the wheels are hopping around and not maitaining contact with the road then I would look at suspension parts. Mine would pull to the left under braking, when I let off the pedal it would come back to the right. The right front caliper piston boot was torn and the piston was sticking which would cause the right front caliper to not apply. Replaced the caliper, problem gone
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
