1LE brakeline problem
Old Mar 27, 2001 | 05:09 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I am in the final stages of my 1LE upgrade.I have encountered a big problem - as I was installing the proportioning valve and master cylinder I found that my 82 Z 28 has
inverted flare brake lines, and the new master cylinder and proportioning valve have ISO metric fittings. Are there some type of adaptors available or do I need to change ALL the brake lines?
So near the end of this upgrade, yet so far away! DAMN
82Z 305 w/comp 270 magnum cam,Edelbrock Performer RPM,Holly 1850-4,serpentine belt drive.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Old Mar 27, 2001 | 08:58 PM
Eightyninef's Avatar
you can hack off the ends and buy a flaring tool. Get the fittings you need, and re-flare the brake lines.
Old Mar 27, 2001 | 09:25 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Larry,I have a flaring tool.But I am unable to locate 3 of the 5 fittings. One of them appears to be 14mm 1.50. I will have to just keep looking I guess. Thanx,ANDYZ28
Old Mar 28, 2001 | 06:44 PM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
When I ordered my porportioning valve for my 1LE brakes, the dealer had a couple different 1LE porportioning valves for different sized fittings. You might want to check with them.
'89 Formula 383 TPI
Old Mar 28, 2001 | 09:36 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Greg,I was unable to locate any fittings that would fit my car .I have the correct propotioning valve. I went over to a friends house tonight,And salveged what I needed from a donor car. I'm all set now. Thanx,ANDYZ28
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
