End links. .Rear. .How long should they be?
Old Mar 28, 2001 | 08:57 PM
Steves ZZ5's Avatar
I'm in the process of swapping the in-tank fuel pump for a Walbro 255. Since I have the entire rear end down on the ground, I'd like to know how long the end links should be.
The car was lowered a couple years ago, and I know when I did the job, I didn't do the end links correctly. All I did was cut the tubes to the stock length of the old ones, and bolt the links back on.
How do I find the correct length? Is there a way to find the correct length in relation to the sway bar? I guess information on the front end link length would be helpful here too.
Thanks guys,
Old Mar 29, 2001 | 07:34 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Go to:
http://www.suspension.com/chevy,camaro.htm
and you can look up the part number for the front end links. Then go to the sway bar bushing page and look for the chart about 1/2-way down the page that gives the lengths of the different end links they carry. I think I ordered the 9-8125 for my rear end links. I can look it up tonight if you need me to...
Greg Westphal
'87 IROC 305TPI/A4
Old Mar 29, 2001 | 07:49 AM
Steves ZZ5's Avatar
Thanks greg, Is there a way to know exactly what I need for a lowered suspension?
Old Mar 29, 2001 | 11:52 AM
Engine: 385 HSR
For the front sway bar, the ends should be parallel with the lower control arm. For the rear sway bar, I think the ends should be parallel with the body mounts, but also have somebody move the rear of the car up and down while you check for clearance with the rear housing cover. For both front and rear, the car should be at rest so you can accurately tell when they are parallel. Driving the front wheels onto ramps and then jacking up the rear from the housing (and supporting it with jack stands) will work.
Greg Westphal
'87 IROC 305TPI/A4
Old Mar 29, 2001 | 05:46 PM
Steves ZZ5's Avatar
Thanks again Greg.
I'm gonna shoot for that stance when I slap everything back together. I'm off to box my rear LCA's now.....Wish me luck.
Old Mar 30, 2001 | 12:43 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Even though you'll be doing something different for your lowered suspension, stock sleeve length is 2 5/8 inches.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Street Lethal
Apr 30, 2019 12:14 PM
InfinityShade
Feb 21, 2016 01:29 PM
formula_novice
Sep 5, 2015 03:58 AM
Warlocksirix
Sep 3, 2015 12:26 PM
gixxer92
Sep 1, 2015 04:32 PM
