Emergency brake problem
Old Apr 3, 2001 | 12:40 PM
1989v6bird's Avatar
I'm having problems with my emerg. brake. It is very loose. when i engage it it does not do anything. is there a way to adjest the tention?
Old Apr 3, 2001 | 05:13 PM
v6-3.1's Avatar
yes there is. if you have a haynes manual it will give you a picture of it. it is a piece located under the car im not too sure of the names so can someone please explain this better?
Old Apr 3, 2001 | 07:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you just get up under the car and look, you'll see the adjustment. It's in the drive shaft tunnel up at the very top a little way behind the back end of the trans. It takes (I think) a ¼" wrench and a 10mm wrench. Just hold the cable end still with the ¼" and tighten up the nut a few turns with the 10mm.
ICON Motorsports
Old Apr 3, 2001 | 09:10 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Block the wheels. then remove the driveshaft. Then you can see what to do. As well as making the job much easier
82Z 305 w/comp 270 magnum cam,Edelbrock Performer RPM,Holly 1850-4,serpentine belt drive.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Old Apr 3, 2001 | 10:24 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
These instructions assume you have drum rear brakes, since you didn't mention which you have. First you need to jack the car up and see if the cables are still in their pockets in the body. If they have come out there will be more slack. Also notice if there is a threaded rod going through the saddle (aka equalizer) or not. It is the metal yoke shaped piece where the two individual e-brake lines from the rear brakes join together. If it has the threaded rod then you can adjust the cable there by turning the nut while holding the flat portion of the threaded rod with a vise grips. Later 90-92 e-brakes don't have this threaded rod. Before you adjust this, you need to make sure the rear brakes are properly adjusted. There is a star wheel which adjusts the drum shoes to the drum. It is accessable through a slot at the bottom of the inside dust shield. There may still be a rubber protective piece plugging the slot. There is a special brake adjusting tool available in the Help section at the Auto Parts store. Or you can use a standard screwdriver. Move the teeth of this star wheel with your screwdriver and check the friction of the brakes by rotating the wheel. You keep adjusting until you get a slight drag. Check how this effected the e-brake pull-up. If it still isn't tight enough, then adjust the nut on that center threaded rod. Spray it with WD40 first. Also it is easier to get to if you remove the driveshaft at the rear end first and let it hang down. Thios will give you enough room to get your hand in there to adjust it easier. I hope this helps. Lon
90 RS Convertible
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
smooth
Aug 18, 2015 06:34 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
