Wilwood Adj Prop valve. Where in HELL do you find adapters???
Jeez louise! I've looked everywhere for adapters to install my prop valve and it's just a no-go situation. Am I the only guy that has bought this prop valve and actually attempted to install it? I'm trying to fit it into an '88 Trans Am with metric fittings - and that seems to be the rub. Any help or ideas would be great because I'm at my wits end...
Steve
Steve's Trans Am Temple
Steve
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Although I don't have a part number I'm sure Moroso sells adaptor kits for people who want to install line locks the same way. I saw a mustang kit and on the label there was a part listing for camaros. I never grabbed the part number though.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
Tried Napa, tried Pep Boys, AutoZone, Advance, Industrial Connectors, Compressor shop... I used the Moroso (or maybe it was the Hurst kit) Install kit for my line lock - worked great for the line lock but it didn't have the needed parts for the prop valve. I'm bummin. The problem seems to lie in the fact that you're going from metric (the original fittings) to standard threading (IIRC) on the prop valve - and it's a pretty big size difference as well.
I may have to start hitting some import shops <shudder> to check their metric stuff.
Thanks fellas,
Steve
Thanks fellas,
Steve
Car: 4
Engine: 6
Transmission: 5
The simplest thing to do would be to cut the metric fitting off a few inches from the end, and store it safely in a box somewhere; flare the line to a std size; get a flare union and a short stick of the right size line to go into the valve; and make an adapter section.
ICON Motorsports
ICON Motorsports
1992rs/ss
Jan 31, 2025 05:10 PM
ambainb
Apr 25, 2016 09:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
