Torque Arm Mount Problems
Old Jul 2, 2010 | 01:29 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Well I converted from Automatic to T-5. The T-5 that I got was for the lip facing towards the transmission whereas mine is facing away. So I bought Energy Suspension 3-1111R. Well the clam shell clamp didn't close with ease at all. So I got a longer bolt, wedged it in and than tightened the bolt. Well, needless to say I was driving down the road when I heard a thunk then again and again. Jacked it up and the clamp got undone. I am not entirely sure if the bolt just fell off or if it broke off.
Can anyone point me as to where to get the right mount? Because that clamp is supposed to close easily so I'm assuming I bought the wrong one?
Old Jul 4, 2010 | 04:52 AM
JTNKTZ's Avatar
Engine: 355/350
Re: Torque Arm Mount Problems
Anyone?
Old Jul 4, 2010 | 07:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Link with info and pics (from Ed Miller):
https://www.thirdgen.org/forums/susp...orque-arm.html
JamesC
Old Jul 4, 2010 | 06:22 PM
JTNKTZ's Avatar
Engine: 355/350
JamesC
I know how to install it, but the clamp isn't closing right so I think I ordered the wrong part? I think I am just going to have to get the razor blade out and start cutting away...
Old Jul 4, 2010 | 07:40 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Its only wrong if it is the same as your stock T5 which is the opposite of what you need. take the original and see if putting it in backwards gives you the same issues.
Old Sep 7, 2010 | 12:46 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Did you ever fix your issue? I'm having the same problem with my T5 swap - The clampshell doesn't want to close properly.
Old Sep 15, 2010 | 08:00 PM
srosscamaro@aol's Avatar
Car: 85 trans am
Engine: 5.7 goodwrench edelbrock everything
Transmission: t-5 stage 2 clutch
Axle/Gears: 3.27 posi
i had the same problem and the bolt ended up pulling the treads out so i bought a new umi torqe arm relocation crossmember this is a very good part and also takes the stress off of ur tailshaft
Old Sep 15, 2010 | 08:03 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
I wound up fixing the problem by taking a dye grinder and grinding the bushing to fit the correct shape of the mount. I had exactly the same issue with exactly the same bushing. Took a little bit to get it perfect, but its all good now.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
