Removing Calipers
Old 04-10-2001, 01:45 AM
pookey's Avatar
Removing Calipers
Never did it before. How hard of a job? Also, I am draining all my brake fluid out of my master cylinder (its as brown as mud). Any good tricks on how to get it all out and get the lines clean?
Old 04-10-2001, 02:27 PM
Ragin'87's Avatar
Not very hard at all. You'll need a 3/8" allen key/socket.. To get out everything you need to bleed the entire system. get the bigger bottle of brake fluid. You can safely gravity bleed the whole system, or if you have a bleeder, or two people it can be done that way. As for cleaning out the lines alcohol can be used to remove residue from old fluid in the lines, BUT YOU HAVE TO GET IT ALL OUT!, to do that you really need to get ALL fluids out of the lines, which will in turn fill your lines with air. I kinda gave you the rundown backwards.. bleeding is the last step, as it will remove any and all things you have in the lines that don't belong there after the alcohol. When you bleed the brakes you want to make sure no more air bubbles are coming out of the bleeder screw with the brake fluid.
Anthony
Old 04-10-2001, 03:48 PM
pookey's Avatar
Thanks for the info. I got the entire system bleed ans when I made my way to the front caliper, I didnt know I needed the F***ING allen wrench. Well of to the store to increase my tools.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
HP52TA
02-03-2018 10:51 PM
MY87LT
Aftermarket Product Review
06-07-2016 09:47 PM
rb85TA
26
09-14-2015 10:29 PM
Stroopwafel
09-11-2015 06:38 AM
Quick Reply: Removing Calipers
