how hard is it to install lower control arms?
Old Apr 10, 2001 | 10:18 PM
david foraker's Avatar
ok, i'm getting ready to start working on my chasis. i'm going to go with steve spohn sub connectors, eldelbrock strut tower brace, and lakewood LCAs. my car takes bumps and corners bad. first i'm going with the LCAs cause i dont have much left from my check. is this a hard install? i'm not much of a mechanic, only thing i've ever installed is an alternator. a just dont want to start taking crap off and not being able to get it back on. oh also i put rear shocks on so... well just need a little info to see if i can attempt this or not. thanks, btw, i now a guy at a collision shop and he is gonna install the subframe connectors on my car for like 50 he said, this is a killer deal right? i dont even no how much regular shops charge.
Old Apr 11, 2001 | 12:39 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Try this: http://www.sc3gfb.org/resources/hotchkis.html
Its for Hotchkis parts but the install should be the same.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Apr 11, 2001 | 07:50 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
LCA's are a piece of cake - thing you gotta remember is do one at a time. If you pull them both off, you might play hell getting the rear-end back in place. Also, torque the bolts with the car back on the ground...
KAM
1992rs/ss
Jan 31, 2025 05:10 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
