Tie Rod Replacement
Old Apr 11, 2001 | 05:57 AM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Tie Rod Replacement
Hey I have the old ones off and am getting ready to put the new ones on. Is there a TORQUE number for the bolts????
Ho do I know if they are tight enough.
Brian
Old Apr 11, 2001 | 07:46 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
I think there is a torque spec for them, but hardly anyone uses it... Most people that I know of just tighten them up good so that they seat and tighten as necessary to put the cotter-pin through the nut...
KAM
Old Apr 11, 2001 | 08:12 AM
82camaro's Avatar
Car: 82 camaro SC
1/4 turn before they break.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Apr 11, 2001 | 05:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
35 Ft-lbs, then tighten (do not loosen) as necessary to insert cotter pin.
Reborn756
Sep 4, 2015 03:42 AM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
BBSDesigns
Aug 11, 2015 07:39 PM
