LCAs or Adj Panhard......?
Old Apr 10, 2001 | 10:35 AM
irocbsa's Avatar
I am dropping the car this weekend with Jamex springs I got from BMR. I was also going to order one of their adj. Panhard rods but got to thinking........I am already going to have to slap relocation brackets on there so why not get the LCAs too. Question #1, which is better to go with first. My research says LCAs. Am I fooling myself??Question #2, When I go to have the relocation brackets welded up how do I determine the proper angle. Do I measure the angle that the LCAs were at when the stock springs were on and then weld accordingly? I'm sure they will outline this in the instructions but you never know. Thanks.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat, Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Apr 10, 2001 | 11:24 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
first go with LCA's trust me i didnt and now im kicking myself b/c of all the wheel hop i get. im puuting them on as soon as in gets warmer here
91 camaro RS
- 305 TBI
Mods: Performer tbi intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter
Soon to come .SLP Posi 323 rear end , Spohn LCA's and panhard bar , Ascd ram air hood, Z28 spoiler and grille , white guage faces.
Old Apr 10, 2001 | 11:56 AM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
I'm JUST done with installing the Jamex springs from BMR myself about an hour ago - and without an APR your rear end will move over to the drivers side quite a bit. I know Im glad I got the APR. That being said - the APR was the biggest PITA to install. I got a Lakewood Industries one, and I swear that was the most frusterating and time consuming part of the whole deal. I installed the springs, APR and all the bushings up front.
Ken
Bright red 86 Iroc-Z Choo Choo Customs Convertible
A few free mods
ChevyKen's Cars (ALL new!!)
Administrator @ ChevyWorld.net (Now in a BRAND NEW Design)
Old Apr 10, 2001 | 04:37 PM
irocbsa's Avatar
Thanks y'all. I think I will go with the Panhard first. Any ideas on the LCA relocation brackets.
Thanks.
bsa
Old Apr 10, 2001 | 09:18 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
dude i had my LAKEWOOD panhard rod installed in about 20 min.
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://photos.yahoo.com/tonysams72
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation/
Old Apr 11, 2001 | 07:45 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
The LCA brackets(Steve Spohn's for example)are made to be mounted first with the existing LCA mount on the rear and them welded to ensure strength. Then you decide where you want to position the LCA. Steve's kit provides 2 mount points:first point restores the OEM angle and second point gives increased traction on launch. These go with 2 being the lowest hole in the bracket. I have mine set at 2 and the results are great with no wheelhop and improved stability at highway speeds.
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,high flow cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit and torque arm,MacEwen White face gauges,84 T/A cold air induction air cleaner,Grant Formula GT wheel.
Old Apr 11, 2001 | 07:25 PM
irocbsa's Avatar
Thanks man. That's what I needed to know.
bsa
1992rs/ss
Jan 31, 2025 05:10 PM
Ed1LE
Sep 30, 2018 09:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Jorlain
Oct 8, 2015 01:57 AM
