Whats with the 16" spacers?
Old Apr 17, 2001 | 09:45 PM
iroc22's Avatar
Why do we need the spacers for the 16" wheels? Is it only for the disc brake rear-ends or for the drums also?
Old Apr 18, 2001 | 01:16 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I thought it was the other way around, only for the drums not the discs.
Old Apr 18, 2001 | 03:51 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You mean the 1/4" inch ones? They came on the rear of my Camaro when I got it, used. I was told its to keep the rear rims and the rear brakes from corroding together. Or maybe to make the rear wheels stick out a bit further for a better stance. Who knows?
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Apr 18, 2001 | 07:01 AM
purpleworm's Avatar
I have them on mine too. I just figured they were for clearance. As it is I have to use stick on wheel weights because there are pieces of metal that catch the weight and drag it arounf the rim. I need and adjustable bar to solve that I think.
91 Z28 Camaro
305 TPI
700R4 with 2000 Stall and shift kit
Old Apr 18, 2001 | 07:44 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
According to the GM parts manuals and my own experiences, they only came on rear-drum cars with the iron drums. This is because the iron drums were thinner than the aluminum drums and the rear rotors.
Greg Westphal
'87 IROC 305TPI/A4
Old Apr 18, 2001 | 10:54 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I have the spacers on my 85 IROC, which has rear disc brakes. There's something in the Chilton manual about the spacers, but I can't recall the details.
JamesC
Old Apr 18, 2001 | 11:40 PM
iroc22's Avatar
yeah the funny thing is that the 16" wheels are labelled FRONT and REAR. When i look at the front wheels, it looks like they already have an intergrated spacer. The 15" 88-90 IROC wheels are interchangable, with no front or rear labelling, and they already seem to have little spacers already.
Old Apr 19, 2001 | 10:10 AM
raging86's Avatar
my 86 roc has aluminum drums and it also has the small spacers. i think it was an easy fix for GM to get the front and rear track aligned. do we all have the same sized spacers? (mine aren't 1/4", mine are more like 1/8") if there are different spacers, here is my theory. there were 3 brake options, disk, aluminum drum, and cast drum. GM probably didn't want to cut a wheel for each type of rear brake, so they made a universal wheel with spacers for each brake system. that is my uneducated guess.
86 IROCZ
T-Tops
700R4
305 TPI
3.23 gears
shift kit, manual TC switch, manual fan switch, flowmaster exhaust with edelbrock TES headers& hollow cat, gutted MAF.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
