3rd and 4th gen rear end swap ?
Old Apr 24, 2001 | 04:40 PM
gcore45's Avatar
Car: '91 RS
Engine: 5.7 tbi
What years of 3rd gen rear are compatible with a '91 Camaro RS? I want to swap in something with disc rears and don't want to change to much other hardware. I specifically want to avoid changing the master cylinder.
On a separate topic, everyone mentions the 4th gen rears cause the tires to stick out on 3rd gens. About 2 inches on either side. Is this with 3rd gen wheels or 4th gen wheels? If the 4th gen wheels don't stick out as much, do they stick out at all. If someone has a website with pictures of what this looks like, post a link.
Thanks in advance,
GCore
Old Apr 25, 2001 | 06:52 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
You can get '90-92 rears with the 28-spline axleshafts (stronger than the earlier 26-spline shafts), rear disc brakes, and either 3.23 or 3.42 gears. The master cylinder will be the same, but you'll need to change the proportioning valve and maybe the e-brake cable(s).
With a 4th-gen rear, the wheels would stick out 2 inches if you had 3rd-gen wheels on, and would be about the same as stock with 4th-gen wheels.
Greg Westphal
'87 IROC 305TPI/A4
Old Apr 25, 2001 | 07:53 AM
82 T-TOP's Avatar
GCore.
I have just done a complete rear end swap. '94 Disc axle onto a '82 T/A. with Drums. No problems. Have not changed M/C or Valve and all works fine. Alot better than with drums. I'm not saying you do not have to change the Valve or M/C. There are many thoughts on this matter. Maybe I've been lucky or will have to later after more brake testing. Yes the 3rd gen, wheels are out 2 more inches. 4th gen wheels have a differant off-set. Tire size is the factor to keep in mind. I'm running 225-60-15 and clear the guard. If you go to 3rd Gen home page and "Readers Rides" I have posted pics of my car. If you need more pics, E-mail me and I can send more detailed ones. Note: go to "brake Conversion: by "lukerene" in this forum. just found pics of my car posted by someone. better than the ones in "Rides"
[This message has been edited by 82 T-TOP (edited April 25, 2001).]
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
