clunking noise
Old Apr 24, 2001 | 04:35 PM
87firebird's Avatar
clunking noise
Whenever I hit a bump that makes the car bounce pretty hard, ther is a clunking noise near the rear. A mechanic said that I should take it to a shop and check out the shocks because he thinks there shot. Is that true. Anybody else have this problem?
Old Apr 25, 2001 | 06:49 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Check the tranny mount first, make sure all of the lug nuts are tight and torqued properly (80 lb-ft for aluminum wheels), and make sure the bolts/nuts for all of the rear suspension components (shocks, lower trailing arms, panhard rod, and torque arm) are tight. If everything checks out OK, then yeah it could be the shocks.
Greg Westphal
'87 IROC 305TPI/A4
Old Apr 25, 2001 | 02:37 PM
KS91Z28's Avatar
I recently had a problem with a clunking noise from the rear. It ended up being the worn out end links on the rear anit-sway bar.
Old Apr 25, 2001 | 04:50 PM
Tas's Avatar
Tas
also check the torque arm mounts on the axle.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Apr 27, 2001 | 11:42 PM
SkyF41's Avatar
My car made a clunking sound whenever i went over bumbs, and it was my tranny mount.Just jack up your car and check that befor you go to a shop.
Old Apr 28, 2001 | 07:20 AM
87firebird's Avatar
I found out what that noise was. It was my exhuast. It was shot, so I put knew exhaust on. It sounds awesome. Its deep as h***.
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
luvofjah
Sep 26, 2015 08:28 PM
ynk1121
Sep 12, 2015 12:27 AM
