Why didn't all the F-bodies get the "wonder bar"?
Old Dec 6, 2000 | 05:36 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I just ordered one of those braces that attach to the bracket that the sway bar attaches to. I also picked one up from the junk yard. Will I notice an improvement in the cars handling?
Zepher
'86 Pontiac Trans Am WS6, 5 Speed:
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Recaro Seats,
Alpine CD+Changer,Rockford & Soundstream Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
WS6 Trans Am
Old Dec 6, 2000 | 08:42 PM
scauffiel's Avatar
It may feel a tad tighter, but probably not. I got mine as preventative medicine for the welds cracking around the steering box (IIRC). Some guys swear it makes a difference, I think it may be a bit tighter, but hard to say - let us know what you think once it's in.
Steve
Steve's Trans Am Temple
Old Dec 7, 2000 | 08:12 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
I put global west units on both of mine. The Formula used to make some idiot noises when the wheels were turned full lock but now it doesn't. I got a bigger 'Yeah Baby!!!' outta myself when I put on the strut tower brace.
Don't have a STB on the GTA but I know I can go around the corners pretty good with the wonder bar on better than before.
'89 Formula - Thunderchicken - 355 Vette L98/T-5/3.45 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Old Dec 7, 2000 | 11:57 AM
sharon's Avatar
Car: 83 Sport Coupe
Engine: 383ci
Transmission: turbo350
I installed an iroc bar under my sport coupe. It made a big difference with the handling as it seemed to have "tightened" up the front end.
Check Out My Website
Sharons Virtual Junkyard
Old Dec 8, 2000 | 01:36 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If all f-bodies got one, there wouldn't be anything "wonder"ful about it!
Old Dec 9, 2000 | 09:43 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
This is a little off topic, but I agree with Brian. I recently installed the Edelbrock strut tower brace. It made a very noticable improvement in the handling on my car.
My question would be why they didnt install a STB from the factory?
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Dec 9, 2000 | 07:02 PM
Jza's Avatar
Jza
It's all about GM watching their bottom line, plus they didn't want the Camaro outhandling their flagship the Corvette.
Old Dec 11, 2000 | 11:02 PM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
Umm. Actually the Camaro came with the wonder bar. It was only the Firebirds and Trans Ams that didn't have it.
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel
Ram-air setup coming soon
Flowmaster muffler
Taylor SpiroPro wires
Accel cap and rotor
Old Dec 12, 2000 | 11:29 AM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
Just to clear this up for me, is the wonderbar the HUGE front sway bar or is it something else?
Thanks,
Jesse
Old Dec 12, 2000 | 12:06 PM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
hey sharon! thats a suave wing you have on the 1983 camaro! where did you get it?
Old Dec 12, 2000 | 12:19 PM
Car: '89 Formula
Engine: 355 TPI
OldblueZ: It's the part in the middle of this picture (courtesy of globalwest). It bolts up under the front sway bar. Globalwest's prices went up... it's now $46. Was $40.
[This message has been edited by Brian Shaughnessy (edited December 12, 2000).]
Old Dec 12, 2000 | 12:33 PM
Buck Mustard's Avatar
Hey - Brian's picture didn't show up... Does anyone else have one? I'm curious also.
Old Dec 12, 2000 | 01:13 PM
MikeS's Avatar
The wonderbar is not the huge swaybar. But it is located in almost the same spot. Maybe these pictures from an older thread will help clear it up.
....if they work, of course.
Old Dec 12, 2000 | 04:16 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
88IROCZ, no, not all Camaros got it; just ones with the "performance suspension", like an IROC... believe me, if it was that easy to find one in a junkyard, I'd have a few by now
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Dec 12, 2000 | 05:11 PM
Zepher's Avatar
There is one more "wonder bar" at the junkyard I got mine at. I might head over there and get the swaybar from the IROC's as well, if they don't charge too much for them.
The "wonder bar" is only $25 from the dealer (actually it's $35, but we get a club discount from the pontiac dealer).
Old Dec 20, 2000 | 04:56 PM
Firechicken92's Avatar
If you say it is only $35 at the dealership then why is globalwest $46? What advantages does the aftermarket one have over the OEM one.
92 Formula 5.7 T-tops
Flowmaster
Other secret mods.
Old Dec 20, 2000 | 06:44 PM
86_327_camaro's Avatar
anyone have the p/n for the wonderbar?
Old Dec 21, 2000 | 11:49 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The Globel West version is much beefier.
JamesC
Old Dec 22, 2000 | 12:19 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
If I purchace one what else would I need. I am assuming it is a bolt on part. Does it come woth bolts? Are the holed pre drilled and tapped in the sub-frame?
Old Dec 22, 2000 | 01:22 PM
JPrevost's Avatar
Car: 91 Red Sled
It uses the sway bar bushing bolts. Install is as easy as unbolting 4 bolts, slipping the bar into place, and bolting those 4 bolts back in.
, Jon (91 RS too many mods to list)
Old Dec 24, 2000 | 05:46 PM
anyone have the p/n's for the wonder bar?
Old Dec 28, 2000 | 10:57 PM
Omar's Avatar
14079634 should be the part number.
1989 IROC-Z 5.7L
Old Dec 30, 2000 | 06:04 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
If you want to know how EASY it is to install, follow this link ----> W Bar Install
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Jan 9, 2001 | 03:25 PM
CamaroEFI's Avatar
would installing a wonder bar and a STB be useless or even better handling
Old Jan 9, 2001 | 09:00 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
do it up!! I'm going as far as a custum ten point roll cage to stiffen the frame along with $1500 worth of suspension add ons.
Old May 13, 2001 | 07:32 PM
Keith5's Avatar
Car: C1500
<font face="Verdana, Arial" size="2">If you want to know how EASY it is to install, follow this link ----> W Bar Install
[/B]</font>
I did it today. I only had to remove 4 bolts to get it off my IROC and 4 bolts to put it on my bird. Where are the other 2 bolts that are described in this tech page?
1989 Pontiac Firebird Formula LO3 Auto
-180 degree stat
-Hooker Cat-Back
velcro t-top bag
Wonder Bar from my IROC
*****Possible summer '01 mods*****
4th gen seats, fiberglass spoiler, new paint
1985 IROC-Z, TPI Auto
-Accel Super Coil
http://www.geocities.com/krt80/
Old May 13, 2001 | 07:51 PM
90 Z28SS's Avatar
I have a 90 Iroc/350/G92 car and the mounting points are there , but no wonder bar came on mine . I didnt even know that some had them till I saw it on here .
Old May 14, 2001 | 12:33 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
<font face="Verdana, Arial" size="2">Originally posted by 90 Z28SS:
I have a 90 Iroc/350/G92 car and the mounting points are there , but no wonder bar came on mine . I didnt even know that some had them till I saw it on here .</font>
That might be the case, but it wont be when I get my hands on your car! I've got a silver powdercoated wonderbar lined up for it!
Old May 15, 2001 | 12:29 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
Don't forget, it's not just taking off the 4 bolts and putting it back up. It's gotta be done w/ a loaded suspension, which means ramps, although, reamps don't work w/ ground effects. you have to jack up the car and put ramps under it.
SUPERCHARGED 87 GTA: Blk/Gld w/Superam, 355cid Trickflows, forged pistons 9.5:1. Auto 2,600 stall, 3.45 9 bolt disc, Best time & mph (Naturally Aspirated): 13.567 @ 101.900 w/ a poor 60ft. Best mph: 104.3 *This car is 100% NYS emissions legal, w/ all emissions controls!* "If you want to have a fast car, hang out w/ those who do!"
http:// www.community.webtv.net/munks87/JustinsGTApage.com
VORTECH S-TRIM, INSTALLATION IN PROGRESS: 10 & 15 LB&gt; PULLEYS, CUSTOM HKS RACE BYPASS, CUSTOM DUCTING W/ COLD AIR, SWAPPING TO SERPENTINE, & MANY EXTRAS! BEST TIME: 11'S I GUESS. WE'LL SEE IN SPRING!
Old May 15, 2001 | 06:00 PM
Keith5's Avatar
Car: C1500
<font face="Verdana, Arial" size="2">Originally posted by Justin 87 GTA:
</font>
I used my ramps to get the bar off my IROC and it has ground effects.
Hotrodboba400
Dec 10, 2019 07:07 PM
PurelyPMD
May 5, 2016 04:57 PM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Nervous2
Oct 8, 2015 10:53 PM
