What should I be looking for ( rear sway bars)
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Okay, I've done some searching but don't have a lot of time right now to read in depth.
My car is a street strip car. I just put a 9 inch in it and need to go a different route with the sway bar.
I'm gonna get the aftermarket installation kit from spohn but need to know what sway bar would best suit my needs and what to get it from. )
I realize theres 19mm to 24mm but can they be found on any models? Is the thicker one better for drag setups?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: What should I be looking for ( rear sway bars)
thicker are better for straight line, it eill help the car launch straighter.
stock, the largers you will find is 24mm. Aftermarket ones can be had to over 1.12" from spohn and UMI, and others im sure.
I have a 1" solid hotckis one lying around i'll never use.
Car: 1986 Camaro SC
Engine: None
Transmission: None
Car: 86 Trans Am
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
