complete rear-end swap?
Old May 18, 2001 | 09:49 AM
darbster's Avatar
i own an 88 sc with crappy gears and drum brakes....if i purchased this complete 87 iroc rear end thats for sale here (3.27 positrac,disc brakes) how difficult would it be to do a complete swap? Im sure someone has done it.
Old May 18, 2001 | 11:13 AM
Chuck Everly's Avatar
You would also need the master cylinder and proportioning valve. Other than that it should be a direct swap. There may be a difference in the flex brake line but I am not sure.
Old May 18, 2001 | 05:00 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You'd also need the e-brake cables. You could get new brake hardware for the calipers, too... maybe even new caliper mounting bolts.
Bendix H5611 is the hardeware kit, covers both calipers, comes with the bushings & slides for the mounting bolts. Bendex #H5014 is a caliper mounting bolt, they come 1/box, so you'd need to order 4.
I got all my stuff (brake hoses, caliper hardware & bolts, caliper rebuild kit, e-brake cables, rear wheel (aka "axleshaft") bearings & seals, etc) from http://www.carparts.com - I used a "$50 off $100 order" coupon.
The axle swap itself is cake. Rebuilding the calipers is semi-difficult. Bleeding the master cylinder and getting a firm brake pedal is a major pain. I'd suggest buying the master cylinder locally... that way in case you get a bad one (like I did, sucker had a torn seal inside), you can return it without going through a hassle.
The Haynes 82-92 manual covers all the specifics for ya!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Terrell351
Jun 13, 2021 01:13 PM
1984HO
Mar 19, 2021 11:59 AM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
