Camber kits
Old Apr 29, 2001 | 03:37 PM
91Camaro's Avatar
Car: 91 Camaro
Engine: 305 TBI
Camber kits
I just installed intrax springs with new struts and shocks on my 91 camaro. Do I need to get a camber kit or will the alignment go completely back to factory setting?
Old Apr 30, 2001 | 03:27 AM
Omar's Avatar
How much of a drop did you do?
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Apr 30, 2001 | 12:58 PM
91Camaro's Avatar
Car: 91 Camaro
Engine: 305 TBI
Its a 2 inch drop in front and 1.8 inch drop in back.
Old May 17, 2001 | 12:49 PM
MelloYello's Avatar
I would kile to know where I can get a camber kit, as my stock camber plates are already maxed out (1.5" drop) thanx
Old May 17, 2001 | 07:56 PM
82camaro's Avatar
Car: 82 camaro SC
Shouldn't need them. What camber setting do you want? With a 2 inch drop you won't want the stock setting. I dropped mine 1.5 inch and I have it set at -.75. But, I can adjust it up to +1.25 without any problem. You should have plenty of adjustment.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old May 17, 2001 | 08:24 PM
MelloYello's Avatar
Like I said, my plates are maxed out - the alignment shop pointed this out to me. I just want to know where I can get a camber kit. Thanx
Old May 18, 2001 | 04:11 AM
89GTA5spd's Avatar
When I dropped 2" with intrax I had the suspension place put in a camber kit. It cost me $30.. but I don't know where they got it from or how they did it. sorry.
Old May 18, 2001 | 08:43 AM
82camaro's Avatar
Car: 82 camaro SC
What are they maxed out at? Is the alignment shop trying to get factory specs? If so, that's not what you want.
82camaro
Old May 19, 2001 | 02:29 AM
Omar's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 82camaro:
What are they maxed out at? Is the alignment shop trying to get factory specs? If so, that's not what you want.</font>
If they are maxed out, they are maxed out. He is correct in looking for a camber kit. I have never seen one made for our cars. If you dont find one and your negative camber is chewing up tires, you might want to consider drop spindles with stock springs for a 2 inch drop.
1989 IROC-Z 5.7L
NOS 150HP kit
Old May 19, 2001 | 09:09 AM
jayg's Avatar
Car: 1992 Formula 350
Here are a few places for caster/camber plates.
http://www.globalwest.net/camaro93.htm
http://www.ground-control.com/gccamcat.htm
http://www.hotpart.com/camaro/castercamber.htm
Old May 19, 2001 | 12:45 PM
82camaro's Avatar
Car: 82 camaro SC
All I'm trying to say is that if, for instance, you have -.5 camber and the alignment shop says "that's not within specs and you need a camber kit", they are wrong. That negative camber is a good thing, as long as it isn't past -.75. It will make your car handle better and wear the tires even. Usually the camber kits are installed to make the camber even more negative for road racing.
82camaro
Old May 20, 2001 | 01:42 AM
91Camaro's Avatar
Car: 91 Camaro
Engine: 305 TBI
Well when i went to the alignment shop the guy told me it isnt completely back to factory settings. I forgot what exactly the numbers were but they werent very far off. He told me as long as i rotate my tires i will be fine. Im gonna go thru my tires right now and if they get too bad ill get the intrax camber kit. Ill post my results after i go thru my tires(might be a while got brand new yokohamas).Oh and will the size of the tire make a diffrence to the setting of the camber?
I have 245s up front and 255s in the back.
Old May 20, 2001 | 10:14 AM
OLDYELLR's Avatar
Car: '85 IROC
Usually when you lower a car, you get increased negative camber, which is what you *want* unless you're only interested in straight line driving. If you do any kind of spirited driving at all, the outside edges of your tires wear down pretty quick. With a stock 3rd gen, it's just about all you can do to get zero camber, let alone negative. Camber kits are for getting more negative camber and positive caster for road racing and autox. They are quite expensive, but you can get quite a lot of negative camber for free by modifying the struts. You have to elongate the holes where the strut mounts to the steering knuckle. By filing the upper holes 1/8" to the outside and the lower holes 1/8" to the inside (towards the strut body), you can get up to 2° negative camber.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Torsen, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
morrow
Jan 13, 2024 12:29 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
rb85TA
26
Sep 14, 2015 10:29 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
