Rear drums to rear discs
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Ive got a 92 Z28 with a drum brake rear end. I got a 91 rear with disc brakes. Do I need to change the master cylinder or proporting valve?? I think someone told me they were the same for late model Camaros?? Thanks for the help.
Car: 1986 Firebird
Engine: 2.8 V6
The master cylinder is the same. In fact that's the same master cylinder that 82-88 f-bodies used for drum brakes (J50 option). I kept my original J50 in case I ever find the 89-92 rear discs in a junkyard.
If you don't trust me
you can verify this through http://www.carparts.com . Put in both cars, and look up the master cylinders.. the part #s are the same.
As to the prop valve, I'm not sure... call a GM place up, and ask for the price of a disc/drum prop valve, and get the part number. Then call another GM place, and ask for the price & part # of a disc/disc prop valve. Then, let us know if they're different!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
[This message has been edited by TomP (edited May 21, 2001).]
you can verify this through http://www.carparts.com . Put in both cars, and look up the master cylinders.. the part #s are the same.As to the prop valve, I'm not sure... call a GM place up, and ask for the price of a disc/drum prop valve, and get the part number. Then call another GM place, and ask for the price & part # of a disc/disc prop valve. Then, let us know if they're different!
