lowered car different angles?
Old May 22, 2001 | 11:08 PM
RARE-ROC-Z's Avatar
ok so i was pondering something.
if you add a poly trans mount you must add washers to the cross member so it will have the right angle, right?
ok so if you lower a car, that means lowering the sprung weight, now that would mean lowering of the trans and engine also, now that would lower the trans but not the angle of the rearend, so now the trans has a different angle towards the rear, and this will wear out the Ujoints faster, and maybe cause a vibration at speeds.
please give me some feedback on this, just so i know my mind wasnt rattling off things.
thanks.
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 9 Bolt Borg-Warner 3.27gears
Bright Red Hardtop/ Grey Custom Interior
mods: AFPR, B&M megashifter-HD4ft cable, Underdrive Pulleys, Ported plenum, K&N's, Magnaflow muffler, Aluminum Driveshaft, Gutted Air Boxes w/ Ram Air, and more!!
soon to have new PAINT, and suspension work
DAILY DRIVER: 1991 S10 2.5L/5SPD -
Old May 23, 2001 | 10:13 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Ok, lowering the car WILL alter driveline angles. Changing the tranny mount will also alter the angle(I understand that some of them are taller than others....) Shimming the crossmember is one way to fix this, but, it decrease ground clearance. (speed bumps become more interesting) Getting a tranny mount that is the correct height would be a better plan.
Lowering your car DOES lower the tranny in relation to the rear end, thus, changing the angle, but, your suspension is designed with that in mind, and is less of an issue.
I typed this over the space of an hour or so, (at work....) so, if I am unclear, let me know.
Have fun.
Old May 23, 2001 | 01:49 PM
RARE-ROC-Z's Avatar
hey man thanks for the feedback. you understand what i was saying!
and why would our suspension be setup for lowering, it cant handle the rear lifted(via AIRSHOCKS)(and no i would never use those), so why would it handle the whole car lowered. it would be a lot of pressure on the vital parts.
anyone else have any idea. what would happen.
and when you buy a poly trans mount, they are all too tall, so you have to shim the cross member, and the shim is only the lenght of a washer, so its no big deal for ground clearance.
Jarrad
TH-700R4
Bright Red Hardtop/ Grey "Custom" Interior
NOT STOCK, NO WHERE CLOSE!
NEW RED PAINT and WELD PROSTARS.
DAILY DRIVER: 1991 GREY S10 2.5L/5SPD -FOR SALE. leaving for army.
Old May 23, 2001 | 05:28 PM
IROC KID's Avatar
I know this is off topic,but wheres the pics Jarrad of the new paint job?,i would like to see them.
[This message has been edited by IROC KID (edited May 23, 2001).]
Old May 23, 2001 | 09:44 PM
82camaro's Avatar
Car: 82 camaro SC
The change in driveshaft is small because the torque arm is connected to the tranny. When you drop the car(tranny) the rear-end will tip as well. The driveshaft needs to be at an angle or it will kill the u-joints. The added angle won't hurt them unless it's extreme--you couldn't lower the car that far. I would worry more about the angle of the LCA's after the lowering job. A front alignment wil also need to be done.
You can jack it up with air shocks without hurting anything. Shimming the tranny won't help anything and it will change the angle of the engine.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old May 23, 2001 | 10:25 PM
RARE-ROC-Z's Avatar
IROCKID, the car went in today, so it will be a few weeks, two at the most.
82camaro- thank you for helping me. i was just thinking and it kinda started to hurt so i thought maybe i was on to something. lol. and i havent thought much about lowering my car since i have NO MONEY now since the car is being painted.
Jarrad
TH-700R4
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
CRFred
Feb 7, 2016 11:39 PM
Linson
Aug 21, 2015 02:12 PM
