Line Lock Switches....
Old May 23, 2001 | 09:26 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
Engine: Almighty LS1
Ok, I've got that TCI LineLock right now... and I'm not sure I like the switch for it.... I also don't like the Hurst switch either...
Anyways... is it possible to do a toggle switch instead of the plunger/trigger style switches ?? I know plunger style is good for quick releases, but I haven't the slightest idea where the hell I'd mount it for it to be eeffective unless I wanna drill a hole in my steering wheel....
Any ideas on other switches or placement of the current switch I've got?
Try to live your lost Illusions
Demon ~ 1983 Z28 ~ Hellfire and Brimstone with a touch of grace.
[This spewing of useless drivel has been danced upon by three naked elves and a small green heffalump name Durf(spewed out Octembuary Seventytwelfth, 2001½).]
Old May 23, 2001 | 10:03 PM
ede's Avatar
ede
i mounted a switch on my stearing wheel. mine is like a phone cord and i used pop rivits to hold a plate on the wheel and the switch in the plate.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 24, 2001 | 02:37 AM
Demon Z28's Avatar
Car: 2001 Camaro SS
do you have pictures of that?? I don't have the cord button... is it worth the $50 !?
I was thinking of just drilling a hole in the steering wheel on the lefthand side in the bar (its an 83 steering wheel so its possible) and running a wire behind the wheel and along the inside of the column or something sorta descreet like that...
Any other thoughts on options?
Old May 24, 2001 | 06:17 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
I hacked off the top of my already shortened stock shifter, had my buddy weld a bolt to the top, ground it down to smooth the welds and sprayed some black paint. Mounted a Hurst t-handle shifter with the button.
I thought I could just grind down the top of the handle and tap the threads but the stock shifter design is actually 2 pieces and that didn't work out.
Anyway, it works great. Easy to access. Looks something like this. Comes in either 3/8" or 7/16" threads. I got 7/16".
'89 Formula - Thunderchicken - 355 Vette L98/T-5/3.45 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Old May 24, 2001 | 01:04 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You could do what I've done for my TCC lockup switch (article under the tech section)... it's home-made but has a "racing" look to it.
I nabbed an old computer power cord from a friend, and cut off the ends. I bought a rocker switch that mounts into a 5/8" hole from Radio Shack. Then I took a scrap of 5/8" heater hose, and cut it into a 6" length.
I soldered the power cord wires onto the switch. Then, I slid the heater hose over the power cord. The Radio Shack switch fit snugly into the end of the heater hose. So, now, I had a switch on a handle!
The other end of the TCC lockup switch goes to the diagnostic connector under the dash, so I put the other end of the power cord wires into there. Then, I wrapped the excess cable (6 feet worth) around the base of my steering column where the column meets the dash. I wrapped the excess clockwise. This made the wire (from the handle) come off the driver's side of the column.
Then, when I race, I hold the heater hose handle in my left hand, put my thumb over the switch, and wrap my fingers around the top of the steering wheel. I shift with my right... when I engage the TCC lockup, I just drop the heater hose, and it falls over the steering column, over to the passenger side (my clock-wise wrapping helps that), out of the way.
I think it looks slick... not too bad for a $3 switch and some extra parts lying around.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 24, 2001 | 05:19 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
hmm...
I've got a 5 speed, don't really want to screw with the ripper shifter or nice new leather **** on it... hehe...
I like the computer switch idea though... got any pictures of it??
Old May 26, 2001 | 12:40 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I've got the same thing as Brian, in 7/16". It works great and its really easy.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
83 Crossfire TA
Jan 3, 2016 01:26 PM
Nick McCardle
Sep 10, 2015 08:36 PM
snakeshooter
Sep 7, 2015 11:13 AM
TBRays98
Sep 6, 2015 05:05 PM
