4th gen. rear
Old May 25, 2001 | 08:09 PM
buddman91rs's Avatar
4th gen. rear
is a 4th gen. rear axle as a whole a direct bolt in? if it has disc brakes do i need new brake lines? can my stock 91 z28 wheels fit on the axle w/o modification? im looking for a reaaxle w/ 3.42's or 3.73's and positraction. i will probably visit a junkyard around here...found a 99 v6 w/ 3.23's and a pegleg for $250, and through other posts this seems like the best route to go because i'd have to pay some body to put the gears and posi in....and that can get pretty expensive..what do yall think?
1991 RS LO3
mods: 14" chrome air cleaner, straight-piped after cat exhaust with one chrome dual tip on the left side.
future mods: headers, removing smog equipment, and as many cheap mods as i can find
aol s/n: budman8503
RACECAR spelled backwards is RACECAR
Old May 25, 2001 | 08:40 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It is a direct bolt-in however it's also 2 inches wider on each side so you'll need proper backspacing wheels or your stock ones will stick out.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old May 25, 2001 | 11:01 PM
kermit_one's Avatar
Go to this link and you can see a few pics of my 92RS with a 4th gen rear and stock wheels.Sorry I don't have any close ups of it though.
http://albums.photopoint.com/j/PopUp...pw=&size=small
92RS,POLO GREEN
Old May 26, 2001 | 11:30 AM
PonchoTA's Avatar
Hey Kermit, that's with the 4th gen rear?? Whoah! Looks really nice! Did you have any probs putting it in? I've heard they are basically just a direct bolt-in, but you know how people talk...!
What about the brakes? Did you upgrade, switch, or anything? Reason I'm asking is because I have an '83 T/A with rear drums, and I want to upgrade to the stronger 4th gen and get the disc brakes too, so any help would be greatly appreciated!
Thanks!
Old May 26, 2001 | 01:27 PM
kermit_one's Avatar
Poncho,Yep thats the 4th gen rear.I was really suprised that my wheels didn't stick out from under the car,they're pretty much dead even with the fennder.It really was a direct swap.it took about 3 hours to do.I went from rear drum to 4 wheel disc.You will need to change the proportioning valve though,I'm still driving it without it but the brakes aren't all that great.I picked one up from a 92 Z28,i just have'nt had time to put it in.The only PITA is the e-brake cables and even they came out alright.They are the only part of the swap that isn't a direct fit.It's hard to explain what needs to be done but once you have the rear in the car its easy to figure out.
92RS,POLO GREEN
Old May 26, 2001 | 01:34 PM
kermit_one's Avatar
Oh,i noticed you have a an 83.Your proportioning valve and master cylinder are different then mine so you may want to check on that first.I don't know if 83 ever had 4 wheel disc but I had a 84 z28 with 4 wheel disc so if it came down to it you could just get a mastercylinder and proportioning valve for that set up.Check out the 1LE posts it has some good info on this subject.
92RS,POLO GREEN
Old May 26, 2001 | 02:45 PM
thanx kermit, nice car..... you didnt have to change brake lines or anything...just swap the axle and put in the proportioning valve? did you use anything else rear suspension wise off the fourth gen?
1991 RS LO3
aol s/n: budman8503
Old May 26, 2001 | 03:16 PM
kermit_one's Avatar
Yeah, Brake lines worked fine,I used the soft line from the 4th gen end it hooked up to my hardline with no problems.(i'm talking about the rubber brake line that connects the rearend hardlines to the hardlines on the body.)I didn't use anything else from the 4th.I already had hotchkis control arms and panhard rod and my sway bar works fine on the 4th gen rear.
92RS,POLO GREEN
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
