Would this work ok?
Car: 1982 Z28 Camaro
Transmission: TH200
Would this work ok?
I need to raise my rear end a couple inches to keep my 10's from hitting fenders, would these be ok?
http://cgi.ebay.com/ebaymotors/ws/eB...%3AMEWAX%3AVRI
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
Re: Would this work ok?
My personal oppinion is I wouldnt do it. Especially if your racing the car or going to be launching the car.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
new springs would be be correct way to do this. Moog Iroc replacements will usually raise the rear of the car at least an inch
Transmission: TH200
my problem is when i hit a bump or have someone sit in the back, the tires rub the fenders easy, I thought about getting air shocks till i read a thread on it and also the car is for mainly cruising.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
4th gen rubber isolators in the top will add 3/4 in from what I read.
Although more expensive than those solid spacers, air ride technoligies makes 'drag bags' - they are air bags that fit inside the coil spring - add pressure and the spring doesn't collapse as easily as quickly. But that would be adjustable - stop at air pump and add air, release when not needed. I'd make the 'friends' pay the $1 for the air if they wanted a ride
Car: 86 Trans Am
Transmission: TH200
i guess since i have tall tires with wide wheels in the rear, I'm thinking of putting smaller tires on the rear and of course the front to match the height. right now I have 255/65/15 on and wondering if i should go with a 225/60/15 or a 215/60/15 in the rear to keep from hitting the fenders, i have 10 inch wheels in the rear. any thoughts what would work better?
Terrell351
Jun 13, 2021 01:13 PM
