Need to replace rear shocks, help?
Old Jun 2, 2001 | 12:01 PM
92fire-audio's Avatar
Can anyone post a little tech article for how to replace the rear shocks?? I'm getting KYB shocks soon and my right rear tire is rubbing on the fender edge so I need help soon.. How difficult are the rear shocks?
Old Jun 2, 2001 | 01:08 PM
Blue92's Avatar
I might be mistaken, but shocks don't have anything to do with height. That is where springs come in. Changing your rear shocks is very simple.
1) Support rear with jackstands loosen bolt on shock mount.
2) Lift up carpet behind back seats, remove foam and take off nut.
3) Go back under car,Take out bolt on shock and remove shock.
4) Replace with new shock.
you might have to play with jacking rear up and down a little bit to get things lined up.
5) Repeat for the other side.
If I forgot something let me know everybody.
Later,
Blue
Pics of my Car
http://albums.photopoint.com/j/View?...781&p=39417549
http://albums.photopoint.com/j/View?...781&p=39417539
http://albums.photopoint.com/j/View?...781&p=29492902
http://albums.photopoint.com/j/View?...781&p=29492901
305TBI, EDL strut tower brace w/spohn SFC's on the way and wonderbar, ASCD big block hood,
Eibach Sportline Springs,
Koni Struts and Shocks,
SSPE lower control arms and Panhard bar,
Hellwig Rear Swaybar and Energy Suspension bushings.Aluminum Driveshaft. Posi-rear
Old Jun 2, 2001 | 06:04 PM
D'sZ-28's Avatar
i agree with that, but what about front struts? I have never changed them before, anything i need to be aware of? And where did you find that cowl hood? i want one
91 z-28
t-tops
305 tpi
k&n open element
tb bypass
fan toggle switch
3:42 gear soon
Old Jun 2, 2001 | 11:31 PM
Blue92's Avatar
The front struts are pretty straight forward, but the bolts are a bitch to get off. Very tight!! The hood is ASCD's big block.
[This message has been edited by Blue92 (edited June 03, 2001).]
Old Jun 3, 2001 | 12:06 AM
I'm pretty sure it is the shocks though. When I push down on that corner of the car, I can get the fender to touch the tire fairly easily.. The ride hieght is the same on both sides though.. I just spent almost $2g's on wheels and tires, so I don't want the fender to rub off any more of the tire..
Thanks for the advice on installing the shocks.
Old Jun 3, 2001 | 08:34 AM
D'sZ-28's Avatar
"The hood is ASCD's big block".....i'm lost,am i supposed to know what that means? maybe i need to sit the bong down
91 z-28
t-tops
305 tpi
k&n open element
tb bypass
fan toggle switch
3:42 gear soon
Old Jun 3, 2001 | 12:11 PM
Blue92's Avatar
"ASCD" stands for American Sports Car Designs. Just put that name in a search site and you will find the site. It would be a good idea to put the bong down no matter if you knew what ASCD was or not. No drugs, more money for mods!
Old Jun 3, 2001 | 12:45 PM
RARE-ROC-Z's Avatar
rear shocks are one of the easiest things to do. seriously just 4 bolts, and a lil helper and you are done.
and the front struts? how in the world do you get the bolts off the top? i have been trying and trying but you cant grip onto anything. thanks
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 9 Bolt Borg-Warner 3.27gears
Bright Red Hardtop/ Grey "Custom" Interior
NOT STOCK, NO WHERE CLOSE!
NEW RED PAINT and WELD PROSTARS.
DAILY DRIVER: 1991 GREY S10 2.5L/5SPD -FOR SALE. leaving for army.
Old Jun 3, 2001 | 04:17 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I changed the shocks and struts on my car. It was not hard.
As far as getting a grip on the strut tower, I used one of those Clench-Wrench tools from Sears. It worked great. The top should have 2 flat spots that you can put the Clench-Wrench on. Then loosen the nut. Just make sure that you support the lower control arm with a jack so that the spring doesn't push it down. Spray WD-40 or somethinglike that on all the bolts first. Then, after your done, get the front end aligned. The strut tower brackets I think are what sets the caster and the camber. That and you gotta have a torque wrench that will go up to 200 ft.lbs. The bolts that are on the steering knuckle need 195 ft.lbs.
Get a Haynes Repair Manual. It'll tell you all you need to know.
Edit: It did increase the sitting height of my car after I did them all.
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
[This message has been edited by AJ_92RS (edited June 03, 2001).]
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
