Brake rotor replacemenet question???
Old Jun 5, 2001 | 06:13 AM
dean's Avatar
Hi!
I need your help. I want to replace my front brake rotors. I already bought them and new brake pads.
Do I have to take the wheel bearings out or not. Could somebody please write down what do I have to do to replace the rotors!
Because If I need to take the wheel bearings off (out) I would have to buy some new.
Thanks in advance!
Old Jun 5, 2001 | 09:11 PM
IROB's Avatar
Car: '83 Z28
Engine: LT1 (in progress)
Yes the outer bearings will have to come off before you can remove the rotor. If you are changing the rotors and pads, you should, for the small amount of money they are, replace the bearings also. You will need to install an inner bearing and seal on the back of the rotor anyways.
Old Jun 6, 2001 | 09:30 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
New seals and bearings are cheap insurance.
I'm putting on my GT Rotors tonite and the old ones will get pulled and stored as they come off.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
z28_AJ
Aug 27, 2015 08:59 PM
redmaroz
Aug 16, 2015 11:40 PM
