Rear Brake Upgrade ??
Old May 24, 2001 | 09:32 PM
Metalifann's Avatar
In the tech artice on upgrading the rear brakes, it gives part numbers for plates for a 9-bolt rear-end. When I put the part#'s into gmpartsdirect.com, they come back as invalid. The 10-bolt #'s come up, but not the 9-bolt. Can anyone help me? Has anyone else done this on a borg-warner 9 bolt rear?
Old May 25, 2001 | 08:29 PM
Metalifann's Avatar
Anyone?
Old May 26, 2001 | 05:46 AM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
You interested in a set? I just sold my 9-bolt and I still have the plates you need to put the big brakes on the 9-bolt. Shoot me an email.
Old May 28, 2001 | 12:17 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I have done the swap, you need to find them used, gm only sells the one side, the other iside is no longer available. I found mine for 50 bucks and they are the updated ones because there was a recall on the first set up. So the new ones that i got are alot lighter.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old May 28, 2001 | 04:57 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
David Auster, you still have the plates? Thanks.....ebmiller88@aol.com
Old May 28, 2001 | 06:59 PM
Car: 1992 Camaro
Engine: 350 miniram
I am selling the brackets to Mettalifan.
Old Jun 7, 2001 | 05:16 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I thought all the 9 bolts had PBR disc brakes? Am I wrong about that?
I am trying to do a rear brake page as well. So I just want it to be accurate
Old Jun 7, 2001 | 07:16 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
<font face="Verdana, Arial" size="2">Right bracket for '89 9 bolt with PBR aluminum calipers is PN 10136851. That's available. Poughkeepsie Chevrolet
here in NY has 2 on the shelf. $44.
Left rear is pn 10136852... supposedly discontinued. I'm looking for one myself right now. </font>
Crap... missed out on a set of plates by not being in the right place at the right time...
AndyZ28: The PBR's only came on 9-bolts on '89's.
'89 Formula - Thunderchicken - 355 Vette L98/T-5/3.45 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Old Jun 7, 2001 | 06:12 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Thanx for the info Brian.
Does anyone have the original box that 10136851, or 10136852 came in?? If so please reply on the 1LE board (Spohn Performance).
[This message has been edited by ANDYZ28 (edited June 08, 2001).]
Frozer!!!
Jan 19, 2024 04:55 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
