Brake problem
Old May 18, 2001 | 11:43 AM
PonchoTA's Avatar
Brake problem
OK, here's one for the brake guru's:
When I'm stopped, I have a firm brake, but as I sit, waiting to go, the brake pedal slowly drops, and drops, and drops towards the floor. If I release and put them back on, the pedal is firm again, then slowly drops again.
Any ideas on what I should check?
Old May 18, 2001 | 02:24 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Check for fluid leaks. Especially around the brake booster where the master cylinder mounts. If it is wet, replace master cylinder.
Old May 18, 2001 | 08:33 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
PonchTA, Does your T/A have any type of high performance cam? Mine did the same thing after I installed a CompCams 270Magnum.
Low manifold vaccuum,etc..
82Z 305 w/comp 270 magnum cam,Edelbrock Performer RPM,Holly 1850-4,serpentine belt drive.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Old May 20, 2001 | 06:34 PM
PonchoTA's Avatar
No leaks, at the wheels, or at the MC/booster. The lines are in OK shape (I'll be changing those later $$$)
No performance cam that I know of, a previous owner may have put one in, but knowing them, I really doubt it! (these are the guys who wouldn't even get a flat _repaired_, they just put a couple of cans of fix-a-flat in the damn tire! <stupid!>
It probably won't really matter as I hope to do an upgrade to rear discs anyway!!
Old May 20, 2001 | 06:43 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Replace the brake shoes,wheel cyls,And clean the drums with brake kleen. That should do it.
Old Jun 5, 2001 | 11:59 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
This is common with a bad master cylinder.
Sometimes they won't leak , they just bypass inside. Remove the mounting bolts on the master and look behind it, sometimes the fluid will go into the booster and not show leakage from the outside.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Jun 6, 2001 | 09:28 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
Yep...internal seal leak.
Old Jun 6, 2001 | 10:31 AM
PonchoTA's Avatar
Thanks guys! I plan to replace the rear with a disc system anyway, so I'll live with it for now and replace the M/C when I do the change-over.
Thanks for the diagnoses!
Old Jun 6, 2001 | 12:16 PM
gmanuel's Avatar
You have a leak. Check the rear wheel cylinders by pulling the brake drum.
Old Jun 7, 2001 | 06:20 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Do not replace the master cylinder with anything exept the original J50 type. Also retain the propotioning valve.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
overdriv
Aug 20, 2015 03:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
