Bad Vibrations! HELP!!!
Old Jun 6, 2001 | 01:12 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Okay, I have yet to figure this out. At 60mph I get a horrible vibration that doesn't go away as speed progresses. I've checked pinion angle, driveshaft balance, wheel/tire balance, lift bar adjustments, u-joints, etc. & it's still exactly the same. Any suggestions or ideas before I take it to a frame shop? The car was in an accident over the winter before I bought it, I had a shop install a new front crossmember & control arms (guy hit a steel construction road plate) but vibration is coming through the rear (feels like a bad u-joint). Plus my new Lakewood lift bars are cracking at the axle mounting brackets! Maybe related, I don't know but I'm at my wits end here! Thanks!
'91 Z28 1LE; 355, Sportsman II heads, Edelbrock TPI w/ 58mm TB, Tremec TKO 5-speed, 3.73's & much, much more
Old Jun 10, 2001 | 02:59 PM
ian's Avatar
ian
Car: 83 berlinetta
Transmission: th 700
HI I had a problem sounds like it could be same & belive it or not just balancing the rear wheels cured it. could be worth a try for small bucks. ifit works let me know.
Old Jun 11, 2001 | 02:50 PM
82camaro's Avatar
Car: 82 camaro SC
Bent axle? If you have a grinding sound with that vibration it might be a bearing.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Jun 13, 2001 | 06:48 PM
82zm6's Avatar
Ed, bring it by the house. We will get it figured out. jon
"ofcourse this is safe!"
Old Jun 14, 2001 | 08:20 AM
Ed1LE's Avatar
Engine: 5.7, 5.0
Yo, wassabi! I'll give you a ring, I was thinking maybe I could throw your 2 rear wheels on just to see if it's still there...mine are balanced but you never know...4-3/4" cowl hood came the other day!
Old Jun 14, 2001 | 08:57 PM
FiReBReTHa's Avatar
82 your sig is hillarious
oh and something to do with steel driveshafts above a certain speed also does it for ya,
im going new shaft and alignment.
gluck,
and 82, sure it is (pulls head back inside window)
91 FireBird 305 V-8
no true mods,
ghetto rigged cold air intake,
"My G/f Once Wanted To Break Up Because Of Competition With The Car."
GheTTo Riggers INC.
We Make Mcgyver look Like Crap
Old Jun 25, 2001 | 10:14 AM
Ed1LE's Avatar
Engine: 5.7, 5.0
Well, 82zm6 & I tore apart my rear this weekend hoping it was just bad wheel bearings but instead discovered a broken tooth on the ring gear. Definitely a vibration maker I'd think. Also discovered both mounting brackets on my Lakewood Lift bars were cracked....WTF is next!?!?
69GTOby
Apr 18, 2016 02:34 PM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
sac92transam
Oct 7, 2015 02:31 PM
InfinityShade
Sep 18, 2015 08:32 PM
gta892000
Sep 16, 2015 12:40 AM
