Ran out of Camber adjustment!
Car: 1986 z28 & 1992 z28
Transmission: 700-R4
Hi,
I just finished installing all of my suspension pieces, and ran into a problem with too much negative camber. I have my strut mounts (Spohn) moved out as far as they can go, and using my bubble level, I have roughly -1.5 degrees of camber on the drivers side and -0.5 degrees on the passenger side. Everything suspension/steering component is new:
Spohn Strut mounts
Koni Struts
Racecraft Drop Spindles
UMI A-arms (Bought these because I bent my stock a-arms trying to install new bushings)
Ground Control Weight Jacks w/ SSS Springs (I am using these for ease of installation and selecting my own spring rate, not to lower the car)
Spohn Tie Rods, Adjuster, Centerlink, Idler Arm
The car has never been in an accident. Does anybody have any suggestions as to what I should do?
Spohn Strut mounts
Koni Struts
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Ran out of Camber adjustment!
may be a dump question, but are you checking these numbers with the suspension loaded or hanging?
since i dealt with every part on your list with no problems except the race-craft spindles, i would favor those, but they could be just fine.
are the tie rods ends hitting the wheels and not letting them sit flat oh the hubs? a problem with the spindles and wide front tires.
The suspension is loaded and I have rolled the car down the driveway and back up into the garage. I had the same problem with belltech drop spindles. I sold them because I also thought they were the source of the problem, but after installing the racecraft spindles, the camber was still a problem. The wheels are not hitting the tie rods, they are 18x8 with 4.75" of backspacing.
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Hi,
Spohn Strut mounts
Koni Struts
Spohn Strut mounts
Koni Struts
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
The strut to spindle bolt is the culprit here possibly: You can buy an adjustable one (not sure if the stock one is already somewhat adjustable) but with this you can also alter SAI and dial in a better overall alignment.. That's how I got mine to be in spec, otherwise the adjustable J+M camber plates wouldn't have been enough.
morrow
Jan 13, 2024 12:29 PM
86CamaroDan
Sep 29, 2015 10:08 PM
rb85TA
26
Sep 14, 2015 10:29 PM
